Supercharger
Old Jul 29, 2018 | 09:27 PM
tomf5327's Avatar
tomf5327
Default Supercharger
Will a supercharger keep my c7 stingray from going from 8 cyl to 4 cyl? I have a m7, in eco mode 7th gear with no evidence that 4cyl is activated.
Old Jul 29, 2018 | 09:36 PM
robert miller's Avatar
robert miller
no it will not
Old Jul 29, 2018 | 09:49 PM
tomf5327's Avatar
tomf5327
Originally Posted by robert miller
no it will not
Am I missing something then? I cant get into 4cyl mode
Old Jul 29, 2018 | 10:59 PM
robert miller
Did tuner cut it off then. I have a A/A TI on my car until it was tuned it was working but then again I never got into boost until it was tuned.
Old Jul 30, 2018 | 12:02 AM
only9balls's Avatar
only9balls
It was likely removed when you had your car tuned, most tuners turn it off. Mine did.
Old Jul 30, 2018 | 11:19 AM
tomf5327's Avatar
tomf5327
yes tuned after supercharger was installed. That explains it then. Thanks all.
Old Jul 30, 2018 | 12:40 PM
Mike@DiabloSport's Avatar
Mike@DiabloSport
Supporting Vendor
The general assumption would be that when adding a supercharger (or any form of FI to any vehicle), you are no longer concerned about eeking out mileage
Old Jul 30, 2018 | 01:05 PM
tomf5327's Avatar
tomf5327
Yes good point. I was being Greedy.😂
Old Jul 30, 2018 | 02:42 PM
Tort's Avatar
Tort
For what it's worth, mine is in the shop now having the tune tweaked. While they're in there playing around with tables, I asked them if they could turn 4-banger mode back on but only above 65mph. Not sure if it can be set that way (based on speed) but if it can, they'll turn mine back on. I expect bad mileage around town but see no reason not to have it when kicked back with cruise control on.
Old Jul 30, 2018 | 03:20 PM
tomf5327's Avatar
tomf5327
Please let us know. Thanks
Old Jul 31, 2018 | 11:46 AM
Tort's Avatar
Tort
Picked it up late yesterday and didn't get a chance to hit the open road and test it but the tuner said they were able to enabled 4-banger mode again and set it 65mph. However, he wasn't entirely sure it would work as intended (he'd never tried it on a '17+). Driving home from the shop I was in Sport mode (A8) and did hit the cruise control in 1mph increments from 66mph-70mph. It didn't display 4 cyl mode being activated at any point but that could be due to several factors and doesn't necessarily mean it's not working. I'll update again after I have a chance to hit the open road and can throw it in eco/touring mode on a nice flat road.
Old Jul 31, 2018 | 11:03 PM
tomf5327's Avatar
tomf5327
thanks for the update
Old Aug 2, 2018 | 12:59 AM
only9balls's Avatar
only9balls
I think I would ask if it could just be limited to Eco mode, and that way, if I really wanted to stretch out the gas mileage, I would just throw it into eco mode.
Old Aug 2, 2018 | 07:05 AM
hunter105's Avatar
hunter105
I installed an Edlebrock in a buddies C7 and Yes in the tune returned by Edlebrock they will tune out the 4 cylinder mode. So I do not know what supercharger you have but I know Edlebrock will De Tune the 4 cylinder feature.
Old Aug 2, 2018 | 12:07 PM
Tort's Avatar
Tort
It didn't sound like it could be tied to a mode....had to be speed and load based I believe. That would be nice though if it only worked in eco mode. Next time I'm in the shop I'll ask/clarify. After more driving though, I can confirm it does not indicate in the dash that it is going into 4 cylinder mode above 65mph like it should be. Tuner has had a hell of a time with the new ECU in these so there may be another table that needs tweaked...
Old Aug 2, 2018 | 04:34 PM
rrsperry's Avatar
rrsperry
That’s why you get a manual transmission.
To Supercharger
