A/C Blower Problem
Old Aug 2, 2018 | 05:02 PM
sfccotton's Avatar
sfccotton
5th Gear
Default A/C Blower Problem
My wife's Stingray is having intermittent blower issues. When the car is cool the HVAC blower works fine. But if the car sits outside the blower will shut off until the car cools down?
Old Aug 3, 2018 | 02:07 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Does the car give you any warning or information on the DIC?
Old Aug 3, 2018 | 03:32 PM
sfccotton's Avatar
sfccotton
5th Gear
No it just stops working if it sits out in the heat. Yesterday it just quit working altogether. I checked all the fuses and they are fine.
Old Aug 3, 2018 | 04:39 PM
Maxpowers's Avatar
Maxpowers
What is the engine temp when this happens? If the car is overheating it may shut off the blower.
Old Aug 3, 2018 | 04:47 PM
subieworx's Avatar
subieworx
It won't. Trust me.
Old Aug 3, 2018 | 05:15 PM
Gearhead Jim
St. Jude Donor '13
If I make a full throttle blast from 0 to xxx on a hot day, the A/C seems to stop working for a few seconds (I can briefly feel the hot humid air coming into the cabin), but everything goes back to normal after I resume normal throttle. Engine tamps are normal and remain so.
Old Aug 3, 2018 | 07:27 PM
sfccotton's Avatar
sfccotton
5th Gear
Engine temps are normal as the car isn't running. This happens after car is sitting outside (115 in the desert). It quit altogether now so I ordered a blower motor assembly. My guess is the resistor is bad so i will just replace the whole assembly rather than figure out the resistor problem. I will see if this works. hard to believe it would go out with 25,000 miles but I guess it did.
To A/C Blower Problem
