Hello, Recently I took apart the driver side door on my 2014 Stingray to fix a speaker rattle, when I put it back together I noticed that the power mirror adjustment for each side of the car is no longer working, along with the power driver seat adjustment. I noticed that the car no longer beeps when pressing the profile buttons on the door either.
I have run through all of the fuses on the front and rear panel and they all check out, So I'm wondering if any of you know if the adjustable mirrors are on the same fuse as the driver power seat, and or where to look next. Thanks.
Reason: spelling
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
Does the driver power seat work? If you disconnect the seat, the mirrors no longer work. I would try disconnecting the big harness plug and plug it back in to make sure the connector seated correctly.
