2018 C7 Axle Back Exhaust
Cruise-In IV Veteran
I went with Borla ATAK, reason being if you are going to spend $2k+ on a cat back, it should be quite aggressive sound wise. Keep in mind if you retain NPP which I did even with my Kooks 2" long tubes + 3" x-pipe it's still fairly docile in stealth mode. So go with an NPP exhaust which gives you the best of both worlds, aggressive sound with the ability to quiet down in areas needed. You won't get much power out of a cat back, it's purely for looks and sound only for the most part.
I went with Borla so I could also mate up their Diffuser:
