Run flats
Old Sep 4, 2018 | 05:13 PM
Taevon lee's Avatar
Taevon lee
Default Run flats
will they self seal small holes? Wife came home a week ago, says the right rear on the stingray is six lbs. low, I check, sure enough six lbs on the nose. I top it off, back to 30lbs. Checked it three times, it’s still full? So I’m guessing it picked up trash, lost 6lbs. Of air, threw it out, sealed its self back up, what else could of taken place, any ideas? I’m courious. Just turned 5,000 mi. Going to take in for a tire rotate, maybe better have them check the right rear?
Old Sep 4, 2018 | 06:13 PM
NashvilleGrandSport's Avatar
NashvilleGrandSport
They do not seal. They are designed to be driven with no air up to 50 miles at 50 mph.
Old Sep 4, 2018 | 06:47 PM
Zjoe6's Avatar
Zjoe6
You can take it off and soap it up to check for bubbles, or let someone else do it at your tire rotation, However you choose to deal with it, you want it fixed. Don't let the pressure drop below 20 psi or you risk sidewall damage and then it can't be repaired.
Old Sep 4, 2018 | 10:19 PM
wrecker3's Avatar
wrecker3
How are you going to rotate them ? You can not go front to rear and Michelin said you can not rotate side to side. Per Michelin Pilot Super Sport tires are in fact an asymmetrical tires, and therefore cannot be rotated side to side.
Old Sep 5, 2018 | 10:08 AM
Taevon lee's Avatar
Taevon lee
Default Rotate
guess I won’t rotate them, thought I read in here that they could be, oh well no biggie thanx for the info.
Old Sep 5, 2018 | 10:28 AM
Kracka's Avatar
Kracka
C7 calls for side-to-side rotation, the tires are not directional, they are asymmetrical. Asymmetrical means a tire has an inside and an outside, but can can rotate either direction, which is why they can be moved from one side of the car to the other. The C7 maintenance schedule calls for this to be done every 7,500 miles.
Old Sep 5, 2018 | 10:34 AM
Taevon lee's Avatar
Taevon lee
Default Rotate
guess I’ll rotate then?
Old Sep 5, 2018 | 10:37 AM
Kracka's Avatar
Kracka
Yes sir, I've been doing so every since I took delivery of my car back in April 2014, 42k miles ago!
Old Sep 6, 2018 | 11:02 PM
Bill Dearborn's Avatar
Bill Dearborn
OP: I think you should check your tire for a puncture from a screw/nail. I just had a puncture on the left rear tire of my Terrain over the weekend. Saw a sudden drop from 35 psi down to 27 and then it held pressure. After we got home I was able to inspect the tire in the driveway and found a screw in the tread. Took it to a shop the next day and had the tire repaired. It had a screw about 2 inches long in the tread and all I can think is the initial pressure drop was caused when the tire was first punctured but after the screw was hammered further in so the head was buried into the rubber the hole was sealed by the screw head.
Bill
Old Sep 9, 2018 | 11:02 AM
Jerrymannal's Avatar
Jerrymannal
Had similar issue on wife’s SRX. Finally determined tire bead was leaking at the rim. Removed tire, used some magic juice on the tire and rim, reinstalled and problem solved. Had the dealer do it and cost me $60. Wife is very happy. Happy wife,happy life.
Old Sep 10, 2018 | 09:30 PM
madrob2020's Avatar
madrob2020
YES, did it on '14 Z51 & now '16 Z. Simply jack rear/frt up, move each to other side. No breaking down of tires/rims. VOILA! Some will say tires set up a pattern that is disrupted when you turn them around facing opposite direction-that I'll leave up to you.
Old Sep 12, 2018 | 09:42 PM
Crash594's Avatar
Crash594
Had same issue with my right rear. They patched it from the inside but still leaks. I took it back and they said there was another hole but they can only patch one hole not more than that.
Old Sep 20, 2018 | 08:16 AM
VettMeister's Avatar
VettMeister
I didn't have a choice, I had to drive on my front left with 0 psi for 85 miles, no issues. Tire was noticeably warmer than the other tires. Drove 50 mph entire way.
Old Sep 20, 2018 | 08:36 AM
madrob2020's Avatar
madrob2020
Went out to go to town yesterday a.m. & 5 psi right rear. These are less than 1K miles & was a small nail. 3rd flat in 3 years. Keep the cheapo T-Handle patch repair & tiny air compressor in storage cubby hole in hatch, that uses the sticky strips to push into hole/pull tool back out & snip off the strip that sticks out. I use a Philips screwdriver to enlarge hole to get tool thru tread & is still difficult to push T-Handle tool + sticky strip thru tire w/o bending tool. Tool is worked in/out to "rough up" inside of hole to better seal. With these low profile tires, it can be tricky to push the tool far enough into tire (hits inside of wheel) to get sticky strip all way thru hole to then pull partially out to snip off. Can be done with tire on car normally, especially fronts which can be turned for more clearance. Since I was in garage, it was easier on the rear to just pull it, patch then re-air. Wouldn't be nearly as much fun in the dark, along a road, pouring rain Definitely cheaper than new MPSS ZP & since I don't track, I'll take my chances-
Old Sep 21, 2018 | 12:37 AM
Avanti's Avatar
Avanti
You are sure it was low? I've seen tire sensors do wonky things from computer glitches or what-have-you.
Also since you did add arr, check the valve-core for adequate tightness (if not previously mentioned). I have seen them just loose enough to seep a little and in the process of checking and adding air the core will turn and snug-up just enough to not leak so quickly, if at all. This sounds most likely to me.
As noted, your tires do NOT self-seal unless someone put in Stop Leak for something similar... and it would likely gloop-up your sensor.
All the best.
Old Sep 28, 2018 | 04:59 PM
Red86Cfour's Avatar
Red86Cfour
Newbie C7 question: Do you need a special programmer like you do for the C6?
To Run flats
