C7 Z06 Rotor Replacement
Old Sep 9, 2018 | 06:30 PM
jchunt's Avatar
jchunt
Cruising
Default C7 Z06 Rotor Replacement
I have run my 2015 Z06 Corvette stock iron rotors for 6 track events and they are starting to crack somewhat. There are a couple of cracks that my index nail will catch in but they are not that long. I was going to change out rotors but wanted to make sure they are at the point to do so. See attached photos. Appreciate your insight!
Old Sep 9, 2018 | 07:01 PM
X25's Avatar
X25
Sr.Random input generator
I don't see any attached pics : )
Old Sep 10, 2018 | 11:19 AM
jchunt's Avatar
jchunt
Cruising
I am not sure why the pictures are not showing up after uploading. Requested some help from the administrator.
Thanks for pointing out.
Old Sep 10, 2018 | 12:01 PM
PeteC7's Avatar
PeteC7
I think you need to have a certain minimum number of posts (like 10 or something) before you can post pictures. Based on description though I bet those rotors have quite a bit of life in them. Based on my experience and talking with others they pretty much stress crack right away on track but it takes quite a while for the cracks to grow to the edge of the rotor (which is when you really need to replace them).
Old Sep 10, 2018 | 08:00 PM
badhabit_wb's Avatar
badhabit_wb
There are lots of photo's on this forum with c7 rotors, I posted some myself. You can probably do a search and compare these photos to your rotors and get a good idea about how long they will last.
To C7 Z06 Rotor Replacement
