After 28,000 miles, I found this last Friday morning. I have a new set of tires on the car now. I believe this to be a camber wear issue. Toe wears out the tire differently.
I want to set the alignment as flat as I can. I don't race the car and I have no need for camber to help me plant rubber on high speed turns. So, I'm open to comments on the numbers to use to flatten the footprint of my car.
I plan on:
Front Camber L = 0.1 R = 0.1
Front Caster L = 7.4 R = 7.4
Front Toe L = 0 R = 0
Rear Camber L = 0.1 R = 0.1
Rear Caster - -
Rear Toe L = 0 R = 0
Comments? Concerns? My alignment is scheduled for tomorrow so any responses need to be discussed, debated, and settled by today!
After 28000 miles on a set of tires I would be happy.
That can be wear from toe or camber. Toe will definitely shred the inside of tires exactly as shown. Many people on here don't understand the affects of dynamic toe change and how that can influence tire wear.
Even wear like that seems to say camber to me. Toe causes a scalloping pattern on the tires but I could be wrong. In any case, I'm looking for comments on my proposed alignment numbers. I want to beat 28,000!
A combination of negative camber and toe out can cause the inside edge to wear much faster. Basically, with toe out you are taking the inside of the tire that has more pressure on it due to negative camber and pushing it forward at the same time thus adding more pressure on that edge. Toe in will move the pressure point due to toe toward the center of the tire as that portion of the tire is turned forward. The best thing to have is zero toe.
However, if you got 28K miles with your current alignment I would say maybe you shouldn't fix something that isn't broken although there is nothing to say the alignment didn't recently slip which means you need to at least have the alignment checked.
I concur. I am pleased with the mileage I got and actually replaced the OEMs with the same tire. I may have had the alignment knocked out with some of the big bumps I've been through as I drove through construction zones. I'll ask for the neutral alignment settings I listed and I really want to see the "before" more than anything. None of the other tires had ANY issues and were showing even wear. Heck, the warning bars weren't warning yet! I think I had really good tire wear.
