New HP Tuner Experience? VS NGauge
I figured I could save time sharing files than having to drive to shop to fix tuning issues. Good drag strip weather is around the corner so need to do some data logging on new build.
Wondering if I should go with the HP Tuner device to data log and fix tune issues or Ngauge?
Any advice?
Any advice?
Ngauge can not "see" and log everything that you can with HP Tuners.
Also you can only copy and load tunes created with HP Tuners to the Ngauge, and then from the Ngauge to the car.
There is no way to tune directly from Ngauge. (You can only switch between different tunes loaded on the gauge.)
This is pretty cool though, if you have both because you can keep backups on your Ngauge incase the dealership flashes over your custom tune doing a recall or something.
This way you can load it back on the spot without a laptop, instead of trying to limp back to your tuner on a heavy modified car, or taking the flatbed...
