C7 Headers Ported Int/Manfold Lean?
Old Oct 2, 2018 | 12:14 PM
phantom1's Avatar
phantom1
Default C7 Headers Ported Int/Manfold Lean?
I installed Mid length headers with hi-flow cats, Titanium Akrapovic X-pipe without cats, ported Intake manifold & throttle body and a AFE air filter. I put 50 miles on the car without a tune and so far no check engine light. I do have a HP MPVI2 tuner and plan to tune it.
My question is, will it run lean without throwing a code?
Old Oct 2, 2018 | 01:55 PM
spinkick's Avatar
spinkick
Leaner than you were How are you going to tune without knowing the AFR?
Old Oct 2, 2018 | 04:28 PM
phantom1's Avatar
phantom1
I'm working with a Tuner and will eventually check the air fuel ratio. Its ok for now, if it was running too lean, then it would throw a code.
Old Oct 5, 2018 | 08:29 PM
phantom1's Avatar
phantom1
From what I understand, it would have to run over 6%-25% leaner to throw a check engine code.
Old Oct 7, 2018 | 09:36 AM
Higgs Boson's Avatar
Higgs Boson
it's not the best way to do it but you can tune part throttle using fuel trims, but not WOT.
To C7 Headers Ported Int/Manfold Lean?
