Anyone Use Powerstop Z26 Pads on Track
I have search all over the C7 forums to see if anyone is using the Powerstop Z26 pads on a Z06 or GS. I just went most of the way through a set of Hawk Yellows in a fairly short amount of time with two track days. I am not a heavy braker on the track so that seems quick.
Thanks for your info...
They are in no way shape or form track pads.
Why would I think I shouldn't? How are they worse for occasional track use than $400 pads that don't show significant different performance. I put this post up to gather information not to answer questions about why I asked my question.
Mikark (02-14-2020)
Received 8,928 Likes
If you look at the Powerstop web page you will notice they do make a High Performance Track Day Pad. I don't know how well they would hold up but at $220 from Amazon to do all 4 wheels they are definitely cheap. Again they don't have any temperature performance info so you will be taking your chances.
https://www.powerstop.com/product/tr...Brake%20Rotors
I can't find any mention of Hawk Yellows on the Hawk web site and have no idea what type of pad they are. However, if you want a light track duty Hask pad for a GS/Z06 you are looking at a Hawk DTC 60 at a minimum. I wouldn't drop down to the HP+ pad as they overheat at 800 degrees F and it is really easy to push the pads over that temperature running a heavy car like the GS/Z06 at speed around a track.
If you meant EBC Yellow pads I haven't been particularly enamored with EBC products. If you want a good pad for the track and street you want something that can handle temps up to at least 1200 degrees.
You could also try the Ferodo 2500 series pads that are designed for street use but hold up reasonably well under light track usage. However, they create a fair amount of dust.
Bill
BradT (10-08-2018)
The Z26s are not a pad that will hold up well under track usage. They are dust free ceramic street pads which typically aren't as good as the stock pads. Even though you may not be a heavy braker it is the number of times you use the brakes during a 20 to 25 minute session with minimal cooling between each application. The rotors and pads get hotter with each brake application and it is easy to push the brake compound past its max temperature rating. Powerstop doesn't provide any information on the temperature performance of its brake pads so you can't be sure those pads are good for anything but the street.
Bill
Bill
I want to find a good balance between street/track use, rotor wear, dust and noise. I don't want to buy new rotors every year and I don't need the best performing pads on the track. I appreciate you input as always.
Thanks Bill. The Hawks I am using now are performance ceramic that come in a black box with yellow lettering. I once heard them referred to as Hawk Yellows so maybe I picked up a bad name for them. I just finished a track day at COTA. It looks like I went through about half of the fronts and about a quarter of the rears. My rotors don't show any noticeable wear or cracks. I daily drive this car at times and will only do about 5-6 track days per year.
Bill
Supporting Vendor
I would guess you used these pads - and they are generally not used on track.
However - the large size of the GS/Z06 brakes does mask that to some extent.
Hawk Performance Ceramic box
The best 'combo' pad we have ever used are the Ferodo DS2500 pads - but the compromise of noise/dust vs. performance is always borderline. That depends on your tolerance for unfriendly street performance and how hard you will run the car on track.
The idea of spending considerable time and money on brakes for track use is very often eye opening for newer track drivers.
BradT (10-08-2018)
As an example, my bro-in-law put a set of Powerstop Z26 pads on his new ZL1 to lessen brake dust. For some reason, he thought they were track “capable”. After 2 25 minute sessions with some above average driving this is the result. Luckily, we were able to salvage the rotors.
Powerstop Track Day
Look at the Powerstop Track Day Pads.
Just ran Raybestos ST43 on my 2016 Stingray at VIR this weekend - Great pad
Lots of stopping power. On the street stop on a dime and give you change!
Supporting Vendor
The best advice I'll give is to not consider wear as the primary goal because it will happen no matter what you run. Select a pad that matches you and your car and realize that any trackable pad is at least partly unpleasant on the street. So get those tools out (or your wallet). Pad changes are easy and fun (lol)
Seeing as you did not blow up the Hawk Ceramics - you would likely be fine with a more moderate track pad. There are a couple of new choices out there at attractive prices to consider such as DBA and Powerstop. I've had more than a few users of both and I would classify them as mid-range but a bit fast wearing. Not sure how painful the dust is and on a newer car that matters.
The more known compounds are Carbotech's mid-range like XP10/XP8 which have a great reputation for not wrecking wheel and paint finish or the Raybestos ST-43. Both are mid range track friction that you would definitely like. You *might* street those but that depends on your tolerance for noise and dust which should be expected.
KNSBrakes, ,Thanks for the info. Which Powerstops were you referring to? I have looked at your web site and appreciate how user friendly it is to find the pads that match my car and its options. It baffles me to go to some web sites and not be able to put in my car's options and have it narrow my choices down to the ones that specifically fit my car.
I just put the Z26 pads on my Z51. No way on earth I would take them on the track. When I bedded the Z26 pads it was the quickest I've ever achieved brake fade - and that was about 10 stops from 60mph-15mph at 0.8g. It's simply not a track pad, they will quickly get into a heat range where they will no longer be effective and other things will unfortunately have to stop the car for you.
