Bonding Rear Tub
Old Oct 24, 2018 | 12:26 AM
jackfogelson's Avatar
jackfogelson
Default Bonding Rear Tub
I well be bonding a new rear tub into my C7; Does anybody know how much adhesive to order? And, is 3M panel adhesive the best; or are there other recommendations.
Thanks,
Jack
Old Oct 24, 2018 | 01:16 PM
sammy burks's Avatar
sammy burks
Active Streak: 90 Days
3M panel bond is what I used I bought it at OReilly auto parts it cost more than on line but if you need more
Old Oct 24, 2018 | 02:12 PM
jackfogelson
Did you do the Rear Floor/Tub? How much did you use? Did you follow the guidelines in the collision guide?
Thank you,
Jack
Old Oct 24, 2018 | 10:50 PM
Dale002's Avatar
Dale002
I've used 3M 08115 you will probably need about 4 to 5 tubes depending if you're doing the bottom and top separately Make sure to align it first.
Old Oct 25, 2018 | 11:52 AM
krwunlv's Avatar
krwunlv
Not sure about the adhesive, however here is a tread about it. Perhaps you can reach out to the other guy that did it.
https://www.corvetteforum.com/forums...placement.html
Ken
To Bonding Rear Tub
