Water temp high?
Old Oct 25, 2018 | 10:44 AM
Red86Cfour's Avatar
Red86Cfour
Default Water temp high?
So I just got a 2014 3LT M7 Z51 with 38K on it and am noticing that the water temp seems to run at 220? My previous 05 liked to run at 190 with the AC on most of the time, so the fans were on keeping the temp and fans from cycling. This car, with AC on as well, seems to run much higher, regardless of outside air temp. Is this normal?
Old Oct 25, 2018 | 12:50 PM
pj-c7's Avatar
pj-c7
I've seen mentioned that 2014's had a higher TSTAT. They went lower after that year. My stock 2016 Z51 ran at 210. Now runs at 198 after installing secondary radiator and tune but still same 2016 TSTAT.
HTH,
Pj
Old Oct 25, 2018 | 02:45 PM
f1reb1rd's Avatar
f1reb1rd
i bought mine 214 new and it ran 220. i thought it was crazy to see but it always stayed at 220 so i had no overheat problems. since then i just sold it for a 2017 z which has a 192 deg thermostat so it reads 198 average. you could swap it out for a lower temp but of course i do not know if the computer will flag it for low temp but to me that would be a good thing
Old Oct 25, 2018 | 03:02 PM
Red86Cfour's Avatar
Red86Cfour
Ok cool thanks Guys. I was real surprised after noticing it that high when my 05 ran so much cooler. When I change the coolant out I'll look for a cooler one.
Old Oct 25, 2018 | 03:21 PM
RapidC84B's Avatar
RapidC84B
All wrong info above... 2014s have a bad analog gauge. There's a TSB for it and no fix. If you pull up the digital readout via tour mode you can see the real temp. The analog gauge sits at 220 and doesn't get accurate until coolant gets at or over 220. The car is mechanically identical to later models as far as cooling system and t-stat.
Old Oct 25, 2018 | 04:09 PM
JMII's Avatar
JMII
Thank you! I assumed this is what is going so maybe you confirmed it.
I've noticed on my '14 the analog gauge reads about 20 degreees higher then the digital gauge. So 220 on the dash but around 198-200 on the Perf screen in Touring under all conditions I've encountered so far. A little higher in traffic or aggressive (not track) driving and little lower when highway cruise. At first I thought the values on the analog gauge might be wrong but then I noticed it just goes to 220 and sits there. So like most modern cars I bet the analog gauge really only shows 3 "ranges": cold, normal and hot. The gauge moves (slowly) between them but to keep customers from freaking out it doesn't readjust for every little 10 degree change. Instead it just settles into the normal range of 220 (right in the middle) when its not cold or hot.
Old Oct 25, 2018 | 04:13 PM
RapidC84B's Avatar
RapidC84B
Yep... they calibrated it for "cold, "you're ok", "oh **** it's hot". Which is dumb on a Corvette type car. The C5s I had weren't that way and they corrected it 2015 and up. I keep mine locked to tour display with the digital read outs on track. Coolant gets in the mid 2teens (215-217) max with mid 260s oil temp being flogged; Stock Z51 cooling and dry-sump with Amsoil 10w40 oil.
If you're on a road trip and keep tour digital up you can see the thermostat cycle as the coolant will go 188 to 195 and then back down again and repeat over and over. The factory t-stat is 192 or 194 I can't recall exactly.
Old Oct 25, 2018 | 05:17 PM
JMII's Avatar
JMII
I think its dumb for any car. Might as well have a gas gauge that says "full", "some", "not much" and "all gone"
For a track car just give me the real number, this way I can back off and see how things respond. If it drops I know everything is OK, but if its constantly high then I clearly need additional cooling. I have an OBD-II smart phone app so I can display temp data from that as well to confirm.
Old Oct 25, 2018 | 06:32 PM
Dcasole's Avatar
Dcasole
On my 2015 the Analog gauge matches the Digital readout and I am hard pressed to get it to go over 195 unless I am beating on it hard at the track , even sitting in Atlanta traffic in the heat of the summer …
Dave
Old Oct 26, 2018 | 06:20 PM
JMII's Avatar
JMII
Actually this dial is beyond stupid
Not sure why GM would highlight the 220 mark when the "normal" temp is around 200 which is actually the harsh mark BELOW the big obvious number.
Even more messed up is the gauge apparently changes scale - large hashes below 220 have 20 degrees of separation but the ones above represent just 10 degrees - this is madness!
I added my own numbers below in yellow next to each hash mark in effort to make sense of it...
Should this go into the Ask Tadge section? Why on earth would GM pick this crazy system?
Old Oct 26, 2018 | 08:18 PM
iclick's Avatar
iclick
Same with my 2015 Stingray and current 2017 GS even in S. LA summer traffic.
Old Oct 28, 2018 | 10:27 AM
Red86Cfour's Avatar
Red86Cfour
My C6 was the same, the water temp gauge reflected actual temp.
I've run through the gauges and can't seem to find water temp. I'm in touring mode. Found trans temp though.....
Old Oct 28, 2018 | 12:06 PM
BrunoTheMellow's Avatar
BrunoTheMellow
HTH,
Pj
What? 210 on the street? That's not normal. Specially with a stock z51
Old Oct 28, 2018 | 12:19 PM
BrunoTheMellow
For a track car just give me the real number, this way I can back off and see how things respond. If it droops I know everything is OK, but if its constantly high then I clearly need additional cooling. I have an OBD-II smart phone app so I can display temp data from that as well to confirm.
You guys are off your meds. Go drive the car hard and tell me the anolog gauge doesnt move up and down as it should.
Old Oct 28, 2018 | 06:32 PM
Silverboost's Avatar
Silverboost
The 14's also have a different fan. The 15's up have a higher wattage fan. You can buy the 15 up fan on Rock Auto for about $200. The fan helps for stop and go driving but will not help once in motion. The analog gauge is terrible it will read 220 for temps under and over 220.
Old Oct 29, 2018 | 12:40 PM
RapidC84B's Avatar
RapidC84B
Touring display and then pick 2nd from the top “performance” sub-group and it displays digital exact read outs.
This applies to 2014s only. Gauge hovers around 220 when the car is warmed up and the actual temp is 195-205. Gauge doesn’t become accurate until 220 and up which the car should never see unless there’s a issue. Even on track mine stays 215-217. If you don’t believe me you can read the TSB on the issue. I posted about it when first getting my 2014 last fall.
Old Oct 29, 2018 | 04:21 PM
BrunoTheMellow
Jeez if this is true. Dear god thats a major fuckup.
Old Oct 29, 2018 | 06:00 PM
JMII's Avatar
JMII
My limited experience (no track time yet) in my 2014 confirms this statement.
Jeez if this is true. Dear god thats a major fuckup.​​​​​
Yes it is!
I was beginning to think I was reading the gauge wrong which is why I put yellow values in my picture above.
Old Oct 31, 2018 | 09:48 AM
Red86Cfour's Avatar
Red86Cfour
Didn't realize there was a touring display. I had that confused with touring mode. Finally found it this morning after the drive into work. I'll be watching it!
To Water temp high?
