Problems starting
Old Nov 3, 2018 | 07:20 PM
Ghostnotes's Avatar
Ghostnotes
Default Problems starting
I'm wondering if anybody has had this same problem. I just finished putting everything back together from my super charger build and I go to start it after loading the new tune and the car does not want to start. I try to start it. I can hear the starter try to engage but not turn. After a few seconds it tells me that I have power steering issues and to check my charging system. I'm thinking that the charging system message is because the car thanks it's running, it does not see any charge output so gives me that Warning. I also could not disengage the parking brake. I made a short video that might help clarify some of it. One of the other reasons why I think that it's thinks that it's running Is because when I step on the throttle I can hear the throttle body opening and closing, Very strange.
Kind of worried that the PCM might be toast but i can read/write with no issues.
I pulled the codes and this is what came up. Key on engine not running.
0x7E8: P0068 - MAP / MAF - Throttle Position Correlation (Permanent)
0x7E8: P0103 - Mass or Volume Air Flow A Circuit High (Permanent)
0x7E8: P0480 - Fan 1 Control Circuit (SES, Pending, Permanent)
0x7E8: P0502 - Vehicle Speed Sensor A Circuit Low (Permanent)
0x7E8: P0691 - Fan 1 Control Circuit Low (SES, Pending, History)
0x7E8: P159F (SES, Pending, Current, History)
I checked all of the fuses under the hood and in the rear.Are there any other locations?
Old Nov 4, 2018 | 07:09 PM
stab1991's Avatar
stab1991
Which supercharger, reason I ask is because I’ve heard of prochrger having an issue with their extension harness for the MAF, still wouldn’t give that problem though. Guessing you have reloaded the tune again? Double check all the connections one more time if above is done. Where is the tune from?
Old Nov 5, 2018 | 07:02 AM
Ghostnotes's Avatar
Ghostnotes
I have the A&A V7 YSi. The code is I'm thinking for the MAF is because I put the 3BAR map on and don't have the scaling right yet.
I found it.
Apparently there is another distribution block just under the fuseblock. It carries the feeder for the steering, electronic brake and fans which correlates with 90% of my issues. The main was loose for whatever reason and all that moving around must have broken the connection. I have AllData which helps me with wiring and just about anything else( I suggest if you are a DIY'er to subscribe). In the end, everything pointed back to that as a source and it was . HOWEVERRRRRRR in the process I broke the dreaded fuseblock tab. So now I have to wait till my new fuseblock comes in to start it. Oh well at least I can put my APR wing on now.......
When all is said and done, I'm either going to put a lock washer on it to make it easier to break loose OR put a little less torque on it and double nut it.....
Old Nov 11, 2018 | 09:14 PM
Avanti's Avatar
Avanti
Get in touch with the supercharger people and whoever sold it to you. Good luck!
To Problems starting
