Tick Tick! Range Product??
Old Nov 5, 2018 | 02:56 PM
BSSlomovic's Avatar
BSSlomovic
Default Tick Tick! Range Product??
I bought my 12/16 Grand Sport half a year ago with 50 miles on the clock. I bought it to be driven like it was meant to be and damn is it a powerful beast. After 1000 miles I heard a ticking from the rear along with a check engine light. My mechanic thought the problem was with the AFM muffler valve motors and he switched both sides on warranty. The ticking returned soon after along with the check engine light. Upon taking apart the muffler he diagnosed that the AFM "valve" in the muffler was broken and the main Chevy dealership are being asses about replacing the muffler; however, my mechanic said it was OK to drive the car until the issue is solved through whatever means. Now to my question; what would be the results of at this point connecting the Range Technology AFM delete? Would it eliminate the check engine light. Would it mute the ticking? I believe even if Chevy replaces the mufflers this will happen again in the future. Thanks!!
Old Nov 5, 2018 | 08:46 PM
djnice's Avatar
djnice
Probably not. I don't remember how it is programmed, but I think the controller has to sense the valve went through a correct open/close cycle to clear the check engine light.
Old Nov 5, 2018 | 08:49 PM
HooosierDaddy's Avatar
HooosierDaddy
Are you talking about the AFM valves (front) or the NPP valves (rear at muffler)?
Old Nov 7, 2018 | 04:23 AM
BSSlomovic's Avatar
BSSlomovic
The AFM.
To Tick Tick! Range Product??
