Slicks and TPMS on C7
Anyone know if a c7 has to have tpms on slicks? If so will car run right during hpde events? Just started hpde this year. Thanks.
I would imagine so. I had tpms sensors fail in my C7 and it screwed up the ABS system. I'm pretty sure they work in conjunction with each other...
I run TMPS with my slicks. The cars systems are tied to tire pressure, including traction control. I really don’t know what would happen if they are missing. And even though I run all off, I suspect the car will behave better knowing tire pressure is ok.
Received 8,929 Likes
When I first got my C7Z I used a set of wheels and Hoosiers that I had left over from my C6Z. Of course the C6Z TPMS won't work with the C7 system so I basically ran without sensors. Didn't have an issue. None of the BS that used to happen with the C6s where missing sensors would limit speed in turns to 55 mph.
I finally had some C7 sensors installed when I changed tires but really haven't noticed any difference between when the car has sensors and when it doesn't (other than I don't have to reset the warning message). Even with the C7 sensors it some times takes several HPDE sessions before the car starts to recognize the sensors in the track wheels Vs the sensors in the street wheels.
I can say having the sensors active has helped me two different times. Two separate times at VIR I picked up some metal in the left rear causing a rapid but not immediate air loss and the system alerted me in sufficient time that I could get the car to the pits.
Bill
Bill
I saw this TPMS disable trick in this magazine article, it is at the bottom of the page
and labeled "The “Easter Egg” Mod" , haven't tried it, but sounds functional.
http://www.carsillustrated.com/secre...d-c7-corvette/
Bill
Bill
Premium Supporting Vendor
Thanks!
Dane
My track wheels came with the wrong TPMS and I ran two events with no noticeable difference in performance. The tire inflation dash light was on and the digital tire readings read "--" for all four wheels. I just dismissed the warning and carried on. I have the correct TPMS installed now but I think it's a nice to have as opposed to a got to have thing. The car ran fantastic either way.
Bill
Bill
Thanks Everyone for your input. Bill I'm of the same mindset as you and knowing where your pressure is at is well worth it just in case a tire does start to run low.
Good to know! Only thing I disagree with is time to read back and forth between TMPS. I swap wheels at the track. The new TMPS system only requires me to drive at 25 mph for a min or so. My car litterally will read the new sensor n a few min. I have done this a lot and it always cuts right over.
You've been lucky with it switching over. I have three sets of factory wheels with factory TPMS sensors and sometimes it works fine and sometimes it takes a tool to make it work at all. I always swap brakes and wheels and road test it before heading to the track. I had it throw a code one time for the rear axle and the only thing I had done was switch tires. That's when I bought the tool.
