Ngauge install in cubby
I am looking to install my ngauge in the cubby behind the radio. I also purchased a gauge mount for in there but I am unsure where to drill for the wires. All the searching I have done says you have to drill for the wires to pass through but no one clearly says where to drill with pictures etc. Anyone on here done this and can shed some light?
I think I chose the rear right lower corner to pass wires through for my intercooler tank temperature gauge.
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
While it is probably possible to do with the radio installed, it is so much easier if you just take the time to remove the dash. None of it is all that complicated, just a handful of screws and then it prys off.
I just installed an A/F gauge in the cubby and I'm not sure I could have routed the wires behind the cubby without it removed, there is very little room.
I did bottom right corner, because that is where I put my gauge. The cubby is basically against a wall so I'm not sure any area is better than any other as far as feeding wires to your destination. If you are connecting to the OBD2, obviously the bottom left makes more sense (but blocks the USB), but I think you may still have some difficulty getting a plug fed to, or through the hole. When I put everything back together I tried to fish some of the extra wire back out of the hole I drilled and my wires were basically pinched in place and would not move.
Thanks to both of you for the replies!
Received 1,762 Likes
I did mine bottom left (2016 Z51). I didn't take it a part but I was real careful when I drilled it...I removed the drill bit from the hole saw. Was hard to get it started but ended up ok.
Guess it would be safer to take it apart but I was lazy
More pics in my album...https://www.corvetteforum.com/g/album/8611774
HTH,
Pj
HTH,
Pj
Guess I will be removing the dash and radio then. Hopefully I don't break clips etc lol.
I will plan on wires going out the bottom right so it is behind the cubby mount as that is the side the mount goes.
I appreciate it guys and I looked at your pics, like your setup pj-c7
I was able to feel up around that area with my hand and could confirm that where I drilled (back, bottom, left) was clear. Everything worked fine except my radio doesn't work now.
