Key FOB 1 or 2
Old Dec 18, 2018 | 10:28 PM
dvhughes's Avatar
dvhughes
8th Gear
Default Key FOB 1 or 2
I recently bought a 2015 Stingray convertible and I love it. How do I tell which key fob is which?
They both work normally as far as I know.
Dennis
St. Petersburg
Old Dec 19, 2018 | 05:55 AM
Sids04's Avatar
Sids04
Following.. same question here
Old Dec 19, 2018 | 09:36 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Usually by the keys you keep on the FOB. The FOBs are not marked a specific number any more. If you use 1 FOB and set it up as the #1 driver, you'll need to differentiate the FOBs so as not to get the wrong one. Nothing worse than grabbing your wife's FOB and get compressed by the steering wheel as the seat adjusts. My wife has the FOB without any keys on it, the only way I can tell them apart.
Elmer
Old Dec 19, 2018 | 10:16 AM
Internets_Ninja's Avatar
Internets_Ninja
Dennis
St. Petersburg
I've seen my dash flash FOB #1 and FOB #2 before but only if it is different from the last FOB that started the vehicle. For example, if you drive the car then park it and you are using FOB1 then you go get FOB2 and start the car, the dash should say FOB #2 is in the car. You know this actually happened so long ago that I'm wondering if it was a dream or if it was real. I think it was real lol.
Old Dec 19, 2018 | 11:28 AM
vader86's Avatar
vader86
Only way is to start the vehicle with one or the other and mark them yourself.
Old Dec 19, 2018 | 05:26 PM
Marcho Polo's Avatar
Marcho Polo
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
when in this situation, go get in the car, set the seat far forward, then save on the door to the number 1 settings. Now, move the seat very far back and save that as the number 2 settings on the door. Turn off the car, take both fobs far away from the car, and bring only one of them back.
Get in the car, turn ignition on, and see which setting it goes to, forward or back? Verify the other fob works by doing the opposite.
It's likely that a used car may have only had one fob and a dealer programmed a third or fourth. Fobs 3 and 4 will not work with the memory settings, and when you use them, nothing will happen.
Yes, some cars will display on the dash, but I don't think I ever saw this on my 2015.
Old Dec 20, 2018 | 07:41 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Elmer
Here's how I do it
To Key FOB 1 or 2
