Almost done
I have been repairing my 2016 stingray for 2 months. I am down to a few remaining issues. The damage was to the right rear. My right rear tail light, brake, turn signal unit is not working. My backup camera that I replaced is not working either.
I have included pictures. There is a connector in the bumper rear harness not connected and I have a stray wire that seems to have a 12v charge. In the pics of the harnesss it appears to go to the positive battery cable; this doesn't make sense since it has a 12v charge already.
Any help is appreciated.
Does the new camera serial number need to be programmed into the radio?
Thanks,
Jack
The camera is plug and play. But there are two different rear cameras, depending on whether or not you have the front camera system. They have different connectors, so it should be impossible to mix them up....unless you made changes to the rear harness.
Try to get the photos working, and let us know which camera system you have.
