Hello - I searched here and Google and coming up nada, I'm asking the ?
I have a 2014 z51 M7, 31k miles, all stock.
While I enjoy leg day driving it, is there any way to reduce the amount a pressure needed to push the clutch pedal? Maybe use a different spring attached to the pedal?
thanks in advance for any ideas.
Have you considered a pedal extension? In theory your leg wouldn't have to extend as much to get the clutch fully in. https://www.ecklerscorvette.com/corv...sion-2014.html
This would not change the effort required or the pivot point but its an easy mod to test. Compared to my Nissan 350Z the C7 clutch is very easy to push in. The Nissan was like having a gym membership! On the flip side the lightest clutch pedal I have ever experienced was a Volvo C30 (nobody bought these they are very rare), I swear you could push it to the floor with just a toe!
I think the OP is trying to reduce the effort required to operate the clutch, not that he can't reach the pedal, which I think is what this extension would do.
Only way to reduce the pedal effort is to lengthen the pedal (which increases the stroke) or change the master cylinder to a smaller bore (which also increases the stroke).
When I bought mine I started extra strength training on the left leg.Now i'm fine.
Funny, lol. My left calf is now larger too. I read guys we're swapping the c5 spring to the c6 to reduce the pressure. I couldn't find an answer, could the c5 fit the c7?
<thanks for the info about the master cylinder. I might just have to live with walking lopsided from a larger left leg, haha>
That spring isn't what your leg is working against, it's not more than a simple pedal return spring. The leg workout you're referring to is from the pressure plate, not the pedal spring.
FWIW I'd thick a stiff clutch is related to the spring fingers on the pressure plate to throw out bearing.
I don't think there is an easy cure, yet some options are posted above.
I also believe there is a tension return spring on the pedal to the under dash framing, yet I don't think
changing that is what the OP is complaining about.
Lastly I didn't see a mention if this was the factory clutch or a replacement.
If replacement, well maybe there is an assembly or product issue.
So a clutch fluid flush may be the only easy option and then report if this improves the situation.
On the C6 many people simply remove the clutch pedal spring altogether without issues, and also without long term issues as well. Much more comfortable to drive.
The original equipment C6 spring was uncomfortable, and switched to the lighter spring, or removing it completely, was much more comfortable car to drive. After years of either modification I never heard of any resulting issues.
I have not yet even looked up under the dash to see if the C7 even has a spring...
