2014 Z51 Tire sizes
Old Jan 15, 2019 | 10:23 AM
jponz57's Avatar
jponz57
Default 2014 Z51 Tire sizes
2014 z51 stock front tire size is 245/35/19 i had a 305/35/20 witch caused all abs problems. I put the stock rear tires on and all the codes went away. I just ordered 18 x 10.5 in racestar wheels will i be able to run a 315/35/18 on the rear without throwing the abs codes due to the front and rear wheels not spinning at the same speed?
Old Jan 15, 2019 | 03:20 PM
JMII's Avatar
JMII
315/35/18 is the exact size match to the stock rear Z51 tire size (285/30/20) in terms of height & circumference which is what the computer cares about. You can check here https://tiresize.com/calculator/
However a 315 should really go on a 11.5" wheel not a 10.5" - the tires will balloon outward causing squirm so its not optimized for handling. Might be OK but its outside of what is normally recommended.
Old Jan 15, 2019 | 04:58 PM
jponz57's Avatar
jponz57
that calculator says my stock front 245/35/19 is 25.8 and the 315/35/18 is 26.7 is that too far off i think i would be better off with a 305/35/18 its 26.4.
Old Jan 15, 2019 | 05:57 PM
JMII's Avatar
JMII
Your post indicated rears so those are the ones you need to match in height. As long as you keep the stock OEM front you'll be fine.
Rear of 315/35/18 and 285/30/20 are the same height, thus you could switch between those two setups and computer would never know anything changed.
Old Jan 15, 2019 | 10:37 PM
jponz57's Avatar
jponz57
i cant find any tires in 315/35/18 besides toyo tq
Old Jan 15, 2019 | 10:44 PM
jponz57's Avatar
jponz57
theres more options in 305/35/18 will i have a problem with those?
Old Jan 16, 2019 | 06:35 PM
JMII's Avatar
JMII
Should work but its getting close to the bottom of the recommended ratio I've seen posted around here.
With tire wear it will get smaller so it might start throwing codes once worn down.
This thread might help: https://www.corvetteforum.com/forums...reet-tire.html
Old Jan 17, 2019 | 04:29 PM
jponz57's Avatar
jponz57
its .3 off from the rear tire size its a 1.1% difference from the stock rear as well from my understanding, it has to be 4% for there to be a problem
To 2014 Z51 Tire sizes
