My 2016 will not start unless i insert the key in the pocket! both keys have new batteries, both remotes lock and unlock the doors, remote start is working. Once I use the pocket and start the car the both keys work for a few days. Battery load test is ok battery holding at 680 amps no loose cables?????
Thanks for the chart tip I will try it.I think there is some issue when the car sits for long periods. I have seen other concerns about the same issue I am having but no posts for repairs?
All of a sudden my primary fob started going through a battery every other week, I would have to go through the whole routine. A new fob cured the issue, but the cars memory feature does not recognize the new fob, so it's only good for unlock and start.
