Drag radial size ?
Old Feb 20, 2019 | 01:18 AM
graysilv's Avatar
graysilv
Default Drag radial size ?
Going with some Mickey Thompson ET Streer R on my C7. Was leaning towards the 27” tire (325/35/18) since its close to stock height . Would the taller 29” (305/45/18) tire have any advantage over the other?
Mods:
100 shot nitrous
LT headers
X pipe
e85
CAI
tune
Old Feb 20, 2019 | 11:56 AM
Livernois Motorsports's Avatar
0Livernois Motorsports
Supporting Tuner
Mods:
100 shot nitrous
LT headers
X pipe
e85
CAI
tune
I would definitely recommend going with the taller 305/45/18 overall this is the best option for the power range you are most likely in and should give you the best traction
Old Feb 20, 2019 | 12:36 PM
C7&7's Avatar
C7&7
The 305/45 is going to rub. Bad. trust me ..
I experimented with a BUNCH of tire sizes and the only ones that fit just right are the 305/35/18. I ran these and they worked perfectly... and I am at 1000+ wheel.
Old Feb 20, 2019 | 01:46 PM
Supporting Tuner
It all depends on what wheel you go with and what offset it is of what will work best so that would be the first thing to know after that the chocie will be easier on the correct tire
Old Feb 20, 2019 | 01:54 PM
C7&7's Avatar
C7&7
I suppose.... I ran 18inch forgelines with a pretty dialed in offset. They rubbed the inside of the fender liner and the back side closest to the rear of the car, when I ran anything bigger than the 305/35.. What freaked me out was it rubbed one of the wheel liner screws that's on that flat surface and put a nice line if the tire... At 180 mph.
Old Feb 20, 2019 | 04:53 PM
Supporting Tuner
Yeah thats definitely not an idea situation for sure glad nothing bad came of it! We normally go with bogart racing wheels if we are going for an all out set up on a build
Old Feb 20, 2019 | 06:39 PM
graysilv's Avatar
graysilv
I have some racestars
18x10.5
8.75 backspace
76 mm wheel offset
Old Feb 20, 2019 | 06:42 PM
graysilv's Avatar
graysilv
what brand of radials where you running? I believe the M/T ET street R only comes in 325/35/18 and 305/45/18
Old Jul 18, 2019 | 03:24 PM
officermartinez's Avatar
officermartinez
Hey C7&7... LTNS!
I've got my 18" rear setup going and I am decently happy with the results thus far. Let me see if I can explain myself with a question that I have about my 18" drag setup.
I went searching for this very topic today and I can't seem to nail down a solid response.
The tire in question: Mickey Thompson's
Tire sizes in question: 305/35-18's vs. 305/40-18's
Platform: C7 (specifically my platform is a 2014 Z51)
The factory rear tire on my C7 with the stock Michelin PSS's is 285/30-20's.
Stock rear tire height on Michelin PSS's is published at 26.8"
It obviously does not rub.
I currently own Mickey Thompson 305/35-18's.
The published tire height of these tires is 26.61"
When I measured this brand new MT tire over and over, the tires measure 26" - 26.1"
There seems to be a discrepancy of 1/2" which makes the tire look a bit short.
There is an OBVIOUS height difference between a stock Michelin rear tire vs. the Mickey Thompson.
This setup does not rub.
I am not throwing any codes or anything like that but I am curious if I should step up to a Mickey Thompson 305/40-18.
The 305/40-18 is published to be 27.99" tall. I just left my local shop that just mounted this exact setup on a C7 Z51.
They appear to fit just fine and it does look like it fills out the fender well a lot better. When we measured the tire, it was again, 1/2" shorter.
The 305/40-18 measured at 27.5"
So, I would really like to hear other C7 owners with these exact setups. I already have a noticeable sway at freeway speeds with my 305/35-18's.
Would the rear end sway get "worse" on a MT 305/40-18's due to the increased sidewall? Will it rub? Any benefits of a 35 vs a 40 series MT drag radial?
Old Jul 18, 2019 | 03:51 PM
C7&7's Avatar
C7&7
Originally Posted by officermartinez
Hey C7&7... LTNS!
Hey Mike. Hope you’re well and glad your car is back!
305/40s will rub bad. I ran them a couple events and they rubbed bad. 305/35 is your best bet.
Old Jul 18, 2019 | 06:20 PM
officermartinez
Thanks! Doing well.. Kind of scary how well I seem to be doing. The only downside is I'm CONSTANTLY working, not being able to enjoy our C7. As for your 305/40's "testing," I'm glad you shared your experiences and yet I'm sorry to hear that they were rubbing bad. So, it looks like I will be keeping our 305/35's. With you having solid experiences with Micky Thompson ET drag radial tires, have you found any better straight line performance 18" tire for the streets?
Old Jul 18, 2019 | 06:31 PM
C7&7's Avatar
C7&7
No not really. I just switched back to my 20s with r888s on them. There might be a 305/35 r888r? That would be the ****
Old Jul 20, 2019 | 03:12 AM
Fast6.3's Avatar
Fast6.3
I run 325/30/19 r888r on cray spiders 19x11 no rubbing also use hoosiers 335/30/18 on a 18x10.5 replica wheels
runs prety good on street
To Drag radial size ?
