Base 19x10 drag radials?
Old Mar 12, 2019 | 09:51 AM
Dave02C5's Avatar
Dave02C5
Default Base 19x10 drag radials?
As the title says what size drag radials are guys running with the base c7 factory rear 19x10? 285? 305?
Old Mar 12, 2019 | 05:17 PM
phantom1's Avatar
phantom1
305/35r19"
Old Mar 12, 2019 | 06:16 PM
thrilled's Avatar
thrilled
I'm running 305/30/20 base 1lt.
Old Mar 12, 2019 | 07:06 PM
Dave02C5's Avatar
Dave02C5
Originally Posted by phantom1
Heck no. 305/35r19"
Those are taller than factory height tires. Wont that screw with the trans/computer on an A8??
How so? Base 1LT came with 19x10 rear wheels.
Old Mar 12, 2019 | 07:41 PM
Dcasole's Avatar
Dcasole
They are taller but not enough to screw with computer... but they are the max size u can put on a 10 inch wheel which makes for a wild ride upstairs as they get loose and move around
Later years came with 19/ 20 combo, but the 20 in lacks enough sidewall and is not worth it if you are making any kind of power
Dave
Old Mar 12, 2019 | 08:18 PM
Dave02C5's Avatar
Dave02C5
Dave
They dont rub on inner fender?
Old Mar 12, 2019 | 09:02 PM
phantom1's Avatar
phantom1
Default Nitto NT05R 305/35-19"
[QUOTE=Dave02C5;1599034319]Those are taller than factory height tires. Wont that screw with the trans/computer on an A8??
The factory 19" tires are 26.9" if I remember correctly. The Nitto NT05R drag radials are 27". They're fine.
Old Mar 12, 2019 | 09:06 PM
Dcasole's Avatar
Dcasole
Not on stock rims they dont
Dave
Old Mar 12, 2019 | 10:24 PM
C2367's Avatar
C2367
I run M/T 285/35R19 About the same height as stock on 19X10 2017 OEM Base Wheels but a 10.5 or 11 inch wheel with the correct offset would give more contact patch. First set lasted 2yrs of often at the strip, on second set. Tires dead hook most runs, the drawback is the tire weight. Going for a taller tire on a base stock car may or should damage your 60' time.
Old Mar 12, 2019 | 10:33 PM
Dcasole's Avatar
Dcasole
Dave
Old Mar 12, 2019 | 11:02 PM
Dave02C5's Avatar
Dave02C5
I went with the 285/35/19. Seemed like the right thing to do considering the stock size and it was $130 more for the 305s..
To Base 19x10 drag radials?
