DRL issues C7 GS
Old Mar 17, 2019 | 07:57 AM
Scotthaldane's Avatar
Scotthaldane
Default DRL issues C7 GS
Hi,
I’ve got a fault on my 2017 GS, the passenger side drl when on auto.
It works when it’s dark and on auto but in day light only the left drl is working.
It Works when sides lights are switched on and main beam as it should.
Does the module in the headlight control the drl as well as the hid as I have had to replace the head light and wondering if there is a difference on the older models.
thanks
Old Sep 11, 2021 | 02:50 PM
Dguth1975's Avatar
Dguth1975
Originally Posted by Scotthaldane
Hi,
thanks
did you find the root cause of this? Mine is doing it and dealer replaced entire headlight unit and still doing it. Must be something electrical, fuse or ground wire.
