No kidding. That could have been really ugly if that thing came off while driving.
Originally Posted by badhabit_wb
Has the car ever been wrecked? I'm surprised that the toe link was loose. No way anybody could have done an alignment on that car with that loose.
yeah tell me about it. Nope never any wrecks ! I’ve never even curbed a wheel. The dealership did remove the trans once to change a gear inside because I complained about a rough second gear... still the same btw, but I’m guessing the dummy tech didn’t torque these bolts after being removed. Going to try to go over every bolt back there this week hopefully, and that’s almost 6 months ago or more. Maybe 7000 miles ago. I’m guessing they were slightly loose and just loosened up over time.
I'd make sure it tightens down and the hole isn't enlarged. It may have done some damage and if so I'd go back to the dealer. Good luck with getting it sorted out.
thank you, I have had it tightened and hit it with a paint marker to see if it moves. If it has been enlarged I’m going to replace it. Never going to the dealer again. They had damaged all my Akrapovic exhaust tips while all this happened initially and I got into a huge argument with the manager who was stating I brought the vehicle in like that. Scums #communitychevrolet Burbank, CA .
