Steering wheel misaligned after install
Old Apr 11, 2019 | 11:58 AM
sick14u2nv's Avatar
sick14u2nv
Default Steering wheel misaligned after install
So, I purchased a carbon fiber wheel for my 2019GS. Before I picked it up on Saturday, I had asked the dealer to install the wheel for me. On my way home I noticed that the wheel is turned to the right while I’m going straight lol. Called the dealer and told them about it and they said they’ll do an alignment. I figured they never touched the alignment of the car so why not just fix the mistake so I said no to alignment. From what I understand there’s only one way the wheel goes in and there’s even an arrow to line it up. My question is, is there a way they could have missed a step that caused the wheel to move out of alignment? Is there any movement even if you have the wheel lined up before tightening? They kept insisting that there was only one way it goes in and only alignment can fix it.
Thank you
Old Apr 11, 2019 | 12:09 PM
Jeff V.'s Avatar
Jeff V.
That's really weird. I just swapped my wheel for an OEM 2016 part, and the splines are definitely keyed. There's only one way it can go on. I wonder if the wheel itself is screwed up?
Old Apr 11, 2019 | 12:11 PM
Internets_Ninja's Avatar
Internets_Ninja
They can do a steering wheel alignment procedure which is likely what they were talking about. Essentially the straighten the wheel and tell the computer to reset center. It's electronic steering so there are no bolts that need to be turned for this.
I replaced my steering wheel myself and I'm surprised a professional tech messed this up. I thought the wheel had a keyway that didn't let you put it on the shaft with an out of center clock.
Old Apr 11, 2019 | 12:16 PM
sick14u2nv's Avatar
sick14u2nv
It was a gm core wrapped in carbon fiber and added some bolstering. other than that, the wheel is a oem equipment. I've read somewhere that there is a little bit of give and take on the wheel without it being tighten and or it has
to be turned all the way to the left?
Old Apr 11, 2019 | 12:18 PM
sick14u2nv's Avatar
sick14u2nv
Ok, I can ask them if that's what they meant. but he was talking about adjusting the tie rod
Old Apr 11, 2019 | 12:32 PM
Jeff V.'s Avatar
Jeff V.
The turn to the left thing is just to get it against the lock so it's easier to remove the bolt.
The rack is power assisted, but there's still a physical shaft between the steering wheel and the rack and pinion. I don't know how a software setting could change the physical angles of the joints.
Old Apr 11, 2019 | 04:35 PM
Kracka's Avatar
Kracka
You need that alignment. Let them fix it and be done with it.
Old Apr 12, 2019 | 09:20 AM
Internets_Ninja
How would changing the steering wheel result in needing an actual alignment? Not to say they are wrong, but thats ridiculous. What did the tech do when he installed the steering wheel?
Ah yes true, but they also have to reset the steering wheel sensor to center if they do this. I'm still surprised its gone this far for just a steering wheel change.
Old Apr 12, 2019 | 10:24 AM
Custom Corvette Accessories's Avatar
Premium Supporting Vendor
You do not need an alignment
The steering wheel is on incorrectly (off center on the splines)
That specific steering wheel has marks on it that align with an arrow on the shaft
I 100% promise you that they are not lined up properly - I have the exact same steering wheel and did the
exact same thing when installing mine
Regards
Chip
Old Apr 12, 2019 | 10:28 AM
RapidC84B's Avatar
RapidC84B
The OEM wheels are keyed and can only go on one way. I've swapped wheels twice. The only way to get it wrong is the somehow force the wheel on over the key-way.
Old Apr 13, 2019 | 11:53 PM
Matthewstorm's Avatar
Matthewstorm
Thank you
Hey! That looks like my steering wheel!
Old Apr 15, 2019 | 08:28 AM
sick14u2nv's Avatar
sick14u2nv
She's all straight now. I asked them to take it off and put it back on and that's all it took.
Thank you everyone!
Old Apr 15, 2019 | 09:48 AM
RapidC84B's Avatar
RapidC84B
I don't understand how they got it wrong? Is that wheel not using an OEM core? There's a key way so it cannot go on the wrong way. If they were able to put it on wrong then something is messed up.
Old Apr 15, 2019 | 11:00 AM
Zjoe6's Avatar
Zjoe6
A dealer? No way. They never mess anything up.
Old Apr 15, 2019 | 11:03 AM
RapidC84B's Avatar
RapidC84B
Found a screenshot of the keyway... they would have had to force it on.
Old Apr 15, 2019 | 04:02 PM
sick14u2nv's Avatar
sick14u2nv
There is a little bit of play there even if you have the arrow ligned up. I brought the wheel the car came with to compare and the play was still there. Maybe there’s a notch that holds the wheel in the back to make it snug when tighten and they somehow missed it I don’t know what to tell you lol. I watched them take it off try the original wheel then put the cf wheel back on tightened it and it was straight. Of course they were just as confused but I know better not to take it back to them for anything other than warranty work. The service manager asked me what kind of lowering springs I have when I asked if they could lower it. As soon as he asked that, I just said nevermind 🤯
To Steering wheel misaligned after install
