4th engine.....
Old Apr 13, 2019 | 11:37 AM
xrayvette's Avatar
xrayvette
Cruising
Default 4th engine.....
So here we are again, cars at the dealer waiting for another engine. The car has only 32k and i do have an extended warranty from GM until 2022 or 98k miles. this is unheard of, this is my 4th vette and never had this issue before. I have contacted GM and they have me on a call back for Monday. What can i do? at this point is there anything else they would be willing to offer me?
Popular Reply
Apr 13, 2019, 12:21 PM
lakemg's Avatar
lakemg
Sounds like the dealer is not installing the engine correctly each time. From what I recall there is an alignment procedure required for mating the engine to the torque tube and if things aren't right it eats the rear main bearings and crank. These engines are way too reliable to have 4 different engine issues in a row with the same car/owner. Something else is going on here
Old Apr 13, 2019 | 11:41 AM
fparkin's Avatar
fparkin
they need to buy back car ,4th engine wow unheard of
Old Apr 13, 2019 | 12:21 PM
lakemg's Avatar
lakemg
Old Apr 13, 2019 | 01:14 PM
Gary barnes 1098's Avatar
Gary barnes 1098
Dealer is definitely doing a bad install!!! Typical for a Chevy dealer. They are incompetent. Such a shame!!!!
Old Apr 13, 2019 | 01:49 PM
RonC7's Avatar
RonC7
This technical article states failure due to torque tube misalignment typically take 3 - 5000 miles. Sure seems suspicious.
https://www.corvetteactioncenter.com...dure-1313.html
Old Apr 13, 2019 | 02:05 PM
383vett's Avatar
383vett
At least you never have had to change the oil.
Old Apr 13, 2019 | 05:21 PM
douglee25's Avatar
douglee25
Is this a dry sump car? Are they reusing the contaminated oil system? Cleaning it out? New?
Old Apr 13, 2019 | 06:15 PM
Avanti's Avatar
Avanti
Probably comparable odds of this (by chance alone) as winning the lottery! It HAS to be incompetent installation(s). One would think on the second install GM would have taken some interest. By the third they'd had enough concern to directly step in. By the forth... well, don't ask.
Old Apr 13, 2019 | 06:20 PM
spinkick's Avatar
spinkick
Torque tube, bad install. Has to be. These motors are so reliable.
Old Apr 13, 2019 | 07:13 PM
ShadowGray19's Avatar
ShadowGray19
Why are you even keeping this car? I would have dumped it after engine number 2. Don't see how you could ever trust the car or be happy with it at this point. Life is too short to deal with this sort of garbage.
Old Apr 13, 2019 | 09:46 PM
JHEBERT's Avatar
JHEBERT
It’s not the car, it’s the techs who have no idea of the proper procedure, even though the info is available. A little extra work, but it’s needed.
Old Apr 17, 2019 | 09:16 AM
Zjoe6's Avatar
Zjoe6
Imagine what these rookies cost GM.
Old Apr 17, 2019 | 11:11 AM
Devin M's Avatar
Devin M
What did each engine fail for?
Old Apr 17, 2019 | 05:59 PM
Operations's Avatar
Operations
I like where your heads at,
To 4th engine.....
