HRE Wheels - rub occasionally
Old Apr 14, 2019 | 05:28 PM
hogurt's Avatar
hogurt
Default HRE Wheels - rub occasionally
I got aome new HRE wheels 19/20's The rear tires are 20's 305/30's. They look awesome, but when cruising, if I hit a bump I hear the awful sound of the rub. It's catching the lip of the fender.
Looking for options.
1. I would add widebody fenders, but I already have the sideskirts and spoiler for stingray and I would rather keep those as they are.
2. Maybe new springa that will tighten the ride?
3. Switch from 305 to 285's?
Ideas?
Old Apr 14, 2019 | 06:07 PM
Bmwmike's Avatar
Bmwmike
Im guesing you have the hre 20x11 73mm offset. those sizes are not really correct for the sting ray so i dont know why hre makes them. you can run a 295 however thats a bit narrow for a 11 inch rim but it is still do able. the proper offset you need is 83mm
Old Apr 14, 2019 | 09:03 PM
hogurt's Avatar
hogurt
Good question. I bought them from a forum member when he got rid of his stingray. He says he didn't have any problems. Maybe his z51 had a stiffer suspension. Looking at the pictures, I think you are exactly correct. 20x11 with a 73mm offset.
Do you think that if I upgrade to the z51 springs and sway...that will prevent the rubbing?
Old Apr 15, 2019 | 10:18 AM
subieworx's Avatar
subieworx
Z51 springs are stiffer, but I doubt that will really help. I would add a bit more camber to it by taking out the washers on the upper control arms.
Old Apr 15, 2019 | 11:11 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
He sold them for a reason, they rub. The offset is incorrect and now you have the problem he had. Sell them and get a properly off-set wheel or rub your fenders raw. Stiff spring and shocks will stop the rubbing but you will not like the ride.
My $.02
Elmer
Old Apr 15, 2019 | 12:32 PM
hogurt's Avatar
hogurt
My $.02
Elmer
I always lower my cars so to me the current ride feels sloppy. I have no problem with a stiffer ride.
I think the easy path will be to go with a little shorter tire. Maybe a 295 instead of 305.
Would the zo6 suspension fit on the stingray?
First will add tighter suspension and then shorter tires. If that doesn't work, widebody.
Old Apr 15, 2019 | 12:33 PM
hogurt's Avatar
hogurt
What camber settings should we have? I like that idea too. I am assuming I could get the track alignment which would change the camber. Thanks. I like the recommendation.
Old Apr 15, 2019 | 01:10 PM
hogurt's Avatar
hogurt
My $.02
Elmer
Old Apr 16, 2019 | 12:36 AM
Avanti's Avatar
Avanti
You've said, or at least implied it yourself, apart from anything else (like wheel off-set), your tires are just too big.
Old Apr 16, 2019 | 06:48 AM
TXshaggy's Avatar
TXshaggy
An easier route would be to get rid of the wheels.
Old Apr 16, 2019 | 07:51 AM
Bmwmike's Avatar
Bmwmike
Why would you go threw a bunch of changes. Just sell the wheels and buy the correct wheels and or tires
Old Apr 17, 2019 | 08:26 PM
hogurt's Avatar
hogurt
I make a bunch of changes regardless. That’s how I improve the car and make it my own. I absolutely love the wheels and I already have them, so it is logical to understand the options. If there are easy options, like improving the suspension, changing the camber, or going to 295 tire, then that’s easy. If it means adding widebody fenders, I am a definite maybe. I am exploring options now.
Old Apr 21, 2019 | 10:14 AM
rrepp's Avatar
rrepp
To each his own, but I don't agree with your logic. Of course you can remedy the situation by means of your choice, but the logical thing to do would be to get some wheels that are correct for for car, then you could still make any mods you wish. Including correcting camber, upgrading suspension, etc. I do not know for certain, but you can probably get the same design wheels ,but with correct offset?
Old Apr 21, 2019 | 07:44 PM
BrunoTheMellow's Avatar
BrunoTheMellow
Just raise the rear a bit.
Yes Z06 springs fit. I did that.
To HRE Wheels - rub occasionally
