Off idle hesitation
Old Apr 28, 2019 | 10:27 AM
The Creeper's Avatar
The Creeper
I just traded my 14 M7 Z51 for a new GS a few days ago, and reading this thread I just realized, over the 35,000 miles I put on it I never had it in eco mode more than a few minutes and only then on the open highway.. It never occurred to me that it could be used on startup or in for city driving.
90% of my driving was happily in sport mode.
Old Apr 28, 2019 | 02:03 PM
ssmith512's Avatar
ssmith512
Originally Posted by spinkick
Get the soler engineering throttle body. It's designed to fix the truck like off idle tip in hesitation.
I'm not affiliated but I do own one
This +1 million. I also own one and am simply, utterly amazed at how much it transformed my 2019 Z's driveability with off idle throttle control and precision. Soler Engineering's MTB is THE real deal.
Old Apr 29, 2019 | 04:46 PM
thrilled's Avatar
thrilled
There’s a company called Vanesse that takes care of it.You can dial it from 0-10.I had mine tuned and it took care of the problem.
Old May 1, 2019 | 10:14 PM
spinkick's Avatar
spinkick
All that this does is increase the speed you travel through the crappy throttle range. You could just as easily press down harder on the pedal. You have to correct the actual problem instead of just moving quickly through it.
Old May 3, 2019 | 11:50 PM
JHEBERT's Avatar
JHEBERT
Yep, and the only REAL way to do it is through tuning. Ever see a stock z gain .3 on the 60’ and .5 in the 1/4mi with just a tune? It won’t happen with a throttle body but it can with a tune.
Old May 4, 2019 | 01:50 AM
spinkick's Avatar
spinkick
I'd be interested to see it on this one. I'm getting tuned plus owning this so my data goes out the window
Old May 4, 2019 | 11:35 AM
Mike@SolerEngr's Avatar
Mike@SolerEngr
Supporting Vendor
This topic has been discussed widely. Throttle body physical modifications and tuning are not mutually exclusive, they rather complement each other. Not enemies, but really good friends they ought to be.
I'd argue that the only real one is a physical modification, for software is only virtual and depends on hardware. What you are actually doing with tune is removing restrictions and letting the mechanical/physical part unrestricted, freer to act at your command.
Thx,
__________________
Soler Performance LLC
support@solerengineering.com
www.solerengineering.com
(251) 468-9786
Old May 5, 2019 | 11:49 PM
Zjoe6's Avatar
Zjoe6
Thx,
I've spent a career providing software patches for mechanical things that didn't work right. I agree with you.
Old May 6, 2019 | 01:02 AM
phalse's Avatar
phalse
i also have a 17 M7, its a little hesitant off-idle sometimes, yes. you kinda learn to drive it just a little more snappy, for lack of a better word. much about this is subjective as it also is gonna depend, no offense, on your footwork. some ppl are just slicker, more snickety with their pedal kung fu. bottom line though its just not all there, while still down low. then theres the thing mentioned by that Fran guy (rpm@youtube) about how the throttle isnt even close to fully open until after 3200 rpm. something like that. so especially from a standing start, youre not getting nearly all of it, not even close, regardless of how far in the pedal is.
anything beyond all this requires your friendly neighborhood mike@soler to help correct. for my part, i'll likely get one then let it relearn on it own and forego a tune. i dont wanna change stuff until my warranty is nearly done, THEN i'll throw on the supercharger and this and this and that. natch, another few hundred bucks for the TB is a no brainer, probly gonna be considered a standard mod someday.
Old May 7, 2019 | 08:01 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Originally Posted by Zjoe6
I love when a thread talks about two completely different things. Like listening to a crazy person talk. Don't make no sense.
Mike, please check us out. This is what many of us perceive, but not normal by any means. Check this thread:
https://www.corvetteforum.com/forums...post1598646214
Thanks,
Originally Posted by rrepp
Have you tried driving in sport mode? That is supposed to improve throttle response whether you have mag ride or not. Electronic throttle takes some getting used to as well. .
Yep, two different issues, different solutions! I drove my 2014 Z51 non MRC always in Sport of Track that provided a more aggressive throttle tip-in. When I got my Grand Sport, I drove in Touring to get the ride I had with the non MRC Z51! Sport was to harsh. It had a slow tip-in so bought a Vitesse throttle controller and when set at 4 or 5 matched what I was used to. Set at 9, I call "boy racer" it was way to excessive IMO.
Then I got the MRC upgrade software and now drive the Grand Sport in Sport Mode to get that nannie threshold, etc and it provides a faster throttle tip-in per the tables below. I now don't need or use the Vitesse as the tip-in is find for me in that Drive Mode. So IF you can solve your perceived throttle problem in Track mode, it's tip-in you may want to change.
However regardless of how fast the throttle opens there is a delay in getting air to start moving through the throttle body. That can be improved with the Mods that Mike@SolarEng provides. Definitely will help.
Old May 8, 2019 | 07:22 PM
rogergcam's Avatar
rogergcam
Default Eco mode
Originally Posted by jim2092
They are not. If you never drive in Eco mode how do you know?
REAL MEM DONT DRIVE INECO MODE!
Old Oct 21, 2019 | 08:53 PM
mxw1's Avatar
mxw1
Originally Posted by mxw1
Hi,
I have a 2017 stingray, base engine with a stick shift. I only have 3k miles on the car, but have noticed it has a off idle hesitation during any light throttle acceleration. It acts like the car is "Cold" and running lean, but it does it all the time even after warm up. In the "Eco mode" it is very rough as it switches from 4 to 8 and I'm wondering if this is normal. I've heard of people with other vehicles ( with automatic transmissions ) that they cannot tell when it switches between 4 and 8 cylinder. Mine is very noticeable. Is this normal?
Thanks,
Mike
I seem to have confused some people with my original post. I have two problems that I've listed and I don't believe they are related. I was just asking two questions about my car.
I have heard something today that may help get my "Off Idle Hesitation" problem corrected by a dealership and would like to know if I'm understanding this correctly.
The GM Global Connect system is used to look at my automobile's ECM Software, cross match it with my VIN number, uses SPS programing, looks at my current software number and then, if their are any ECM software updates available it can update my ECM with the latest revision..
Is there someone familiar with this? Am I understanding this correctly ?
Thanks,
Mike
