Please Help
Old Apr 16, 2019 | 10:16 PM
Mr. Lavanzel's Avatar
Mr. Lavanzel
7th Gear
Default Please Help
I just did a diagnostic at GM and this came back: "found torque tube front bearing walking back" and "excessive crank shaft end play"? Can anyone PLEASE explain this. I own a 2017 C7 grand sport. Yes newer car but voided my warranty because of mods 😫. Am I in the creek now with this issue? My car shakes before it can switch gears with a manual and even stopped in mid drive on the freeway. When I try to start it up, it cranks but doesn't kick over then eventually kills the battery after 2 or 3 tries. Please help.. GM is trying to make me change the whole engine with other things at $22k. That's ridiculous
Old Apr 16, 2019 | 10:45 PM
LT4CMG's Avatar
LT4CMG
Just curious, what mods do you have that killed your warranty? Usually dealer tells GM that a specific mod seems like the cause of the failure. Also, is this a manual or automatic car?
Old Apr 16, 2019 | 10:51 PM
Widebodyvette's Avatar
Widebodyvette
1st Gear
I removed the cats and did a muffler delete. I went to Rydell GM and they put a block on it and I didnt know. 2 days later i put everything back on stock and tried to get it cleared but the new Keyes GM saw the welds and officially declared my vin blocked in the system. They did say it was the reason but this is my 3rd vette from 2015 and all had this same mod with no issues. Now this... and they quote $22k
Old Apr 17, 2019 | 07:41 AM
Flame Red's Avatar
Flame Red
From what I have read, if the torque tube is not installed correctly, the engine will eventually be destroyed and need to be replaced.
Did you or some prior owner play with the torque tube or disconnect the engine from the torque tube?
$22k sounds about right for a new engine from a Stealership without any warranty. Sorry to say that you are screwed.
Old Apr 17, 2019 | 08:15 AM
Kevin Parent's Avatar
Kevin Parent
Crankshaft end play= trust bearing F'd.
Old Apr 17, 2019 | 08:34 AM
sstonebreaker's Avatar
sstonebreaker
Well, if you have to get a new engine anyway.... now's the time to start the serious mods!
Old Apr 17, 2019 | 08:54 AM
subieworx's Avatar
subieworx
If the engine is dieing on the highway you most likely have a bad bearing which would be consistent with the excessive thrust play on the crank. Time for a new engine.
Old Apr 17, 2019 | 09:40 AM
RonC7's Avatar
RonC7
OP, these service bulletins may be relevant to your issue. I don't see how a possible assembly issue is related to exhaust system mods. Did you do any work on the clutch, torque tube, or transmission that would have disturbed the torque tube connection?
https://www.corvetteactioncenter.com...tart-1295.html
https://www.corvetteactioncenter.com...dure-1313.html
Old Apr 17, 2019 | 11:08 AM
Devin M's Avatar
Devin M
what is a block? How did the exhaust affect torque tube? How long ago did you do mods? Where were the welds?
Sorry i I have lots of questions , just want to be sure I don’t have the same thing happen if similar mods were done
Old Apr 19, 2019 | 08:12 AM
us3rname's Avatar
us3rname
For less than 22k you can get a bad *** build. Seems really shady that they would void the warranty over exhaust mods. Heck, I supercharged my stingray and they did the trans flush under warranty.
Old Apr 19, 2019 | 08:46 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
This thread has Deja Vu written all over it. If you take off the CATs, you need O2 sims, a tune or both. As in the other thread, was the tune touched? If so, the case is closed.
Elmer
To Please Help
