i have a 2016 c7 im getting code p0335 crankshaft position sensor circuit. Car runs but takes a few seconds to start the idle is off and the rpms reads zero. i already checked all the wiring it looks good changed the crank sensor twice, cam sensor also, new ecu and i also already replaced he reluctor wheel. and the car is still giving me that code. It all started right after i pulled the motor out cause it broke a valve and damaged a piston so i replaced the piston and put a brand new cylinder head. car was running perfect before it broke the valve. i am getting my ground and my 5 volt reference to the crank sensor im just not getting my sensor signal. Sensor signal wire gives me the same readings as my 5 volt reference wire.THANKS
Depends on how you are measuring. A voltmeter shows average voltage. It will not show pulses. Pulses take a scope. Will the car start if the sensor is unplugged?
Yes the car starts with the sensor unpluged. With the car running sensor pluged in the reading doesnt change theres no pluses like there should be cause i checked on another c7 using a test light it reads different volts in the signal wire like it should.
