Vacuum leak?
Old May 3, 2019 | 11:47 AM
seCen's Avatar
seCen
Default Vacuum leak?
So my only mods is a supercharger and header. Car was running fine before I sprayed some seafoam into the throttlebody. Now the car is not running correctly. The fuel trim is out of wack. It idles rough. Sometimes the afr would drop to low 10.xx and the rpm would hoover around 500 when im in neutral after coming to a stop then goes back up to 13.xx-14.xx afr after like 5-10 seconds.
Do you think the seafoam fouled any sensors? Or is there a vacuum leak somewhere? I retighten all the clamps. I ordered a new evap canister vent, maf, and a pcv valve just to see if that would fix the issue.
Old May 3, 2019 | 02:28 PM
a/c man's Avatar
a/c man
Oil on sensors would be my guess they make a throttle body cleaner
Old May 3, 2019 | 05:05 PM
seCen's Avatar
seCen
Going to take off one of the o2 sensors tonight to check if its covered in fluids.
Old May 5, 2019 | 09:50 PM
GeorgeR_Zed06's Avatar
GeorgeR_Zed06
swap out your spark plugs...
Old May 6, 2019 | 07:05 PM
seCen's Avatar
seCen
I took them all out and cleaned them. Same problem still persist. I bought new maf, evap canister, and pcv valve and none of them fixed the problem. My only idea left is the o2 sensors is fouled. Have time tonight to check them out.
Old May 7, 2019 | 07:58 AM
Silvah Goat's Avatar
Silvah Goat
Curious what you find.
To Vacuum leak?
