TPMS Monitor System stopped working
I bought some new BC Forged wheels for Summer driving and had the store install the ACDelco 13598775 TPMS sensors. The TPMS system worked fine for the first 75-100 miles, but now the system doesn't see any of the sensors. I bought a EL50448 scan tool thinking that I needed to reset them, but the tool didn't work. So I then took the car to the dealer and they tried to scan the TPMS sensors, and got the same results.
Has anyone had this problem before? Will I need to remove the old TPMS sensors from the OEM wheels and have them installed on the new wheels?
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,822 Likes
2015 C7 of the Year Finalist
According to my running notes file, The C7 uses the ACDelco part #13581559 or #13581560 for TPMS. Part numbers can change but that's the last info I show. Nope, more digging shows what you have is correct, 13598775 is a newer part number. I can't help ya, sorry.
Elmer
Thank you for the information. I tried doing the auto-connect procedure, but when I put the car into gear from the TPMS learning mode, the learning mode turned off. I read someone else say they had to drive 200+ miles before the sensors picked up.
Received 8,930 Likes
Bill
If they don't wake up or the car recognize the sensors after a few miles I might inquire to the store where they got the sensors. I suppose its possible that these sat on a shelf long enough for the batteries to wear out. I've bought OE sensors that were doa. But if you have sensors with a new part number that sort of implies that they're not that old. I dunno, good luck!
I’m having the same issue as you and Bill Dearborn. Sometimes my track wheel sensors work perfect, and sometimes they don’t work at all. this track weekend they worked fine while driving to hotel but 20 mins into my drive I lost the front passenger one. Pulled over, put the car into learn mode, nothing. Did this three times over the course of a 2 hour drive. Then bang all of a sudden it worked. Next morning head to the track and still working. Second lap of my day, all of them gone at once. and i cant get them to come back on. This is getting really frustrating. I’m about to buy a scan tool but it looks like that didn’t work for you either. Have you figured anything out in since your original post?
Do you need to release air from the tire for it to learn? My other GM car uses the method of setting the car to learn and then you let air out of each tire until the horn chirps, then next tire until all are picked up 2 chirps and done.
OP - It would be odd that all 4 sensors worked and then stopped working due to dead batteries. A little to coincidental. Did you figure out the issue?
Just bought the EL50448. Started the car, I put it in Learn Mode via the DIC, and then went around each corner with the EL50448 and it learned all four sensors immediately. I think my problem is that some of my sensors don’t consistently “wake up” when they are supposed to. I think the EL50448 wakes them up when you scan them. Hopefully this continues to work in the future but with how inconsistent these sensors have been I’m not going to bank on it.
evilkid500 (08-16-2019)
