XM favorite buttons
Old May 13, 2019 | 09:33 AM
JRGARDEN's Avatar
JRGARDEN
Default XM favorite buttons
I just programmed about 15 XM channels on my 2016 C7, When the engine is not running, I can scroll thru the channels on the steering wheel and see them on the dash and the nav screen so I know they are loaded. The minute I fire up the car the scroll (fav) steering wheel buttons stop working and the channels are not displayed. Solution? Thanks J
Old May 13, 2019 | 11:29 AM
KCLARK's Avatar
KCLARK
have to go thru display settings and select the number of PRESETS you want to see. its an option in there for it, but if you have them programmed in order then the steering wheel control will show the display of all of them you saved up in the center of the dash/rpm/mph area.
Old May 13, 2019 | 11:35 AM
JRGARDEN's Avatar
JRGARDEN
Yes I did that and they do display in the center and I can scroll thru them....the strange problem is, when I start the car, the controls on the steering wheel don't work anymore and I can't change the channels with the steering wheel control.....nor does the channels show up in the HUD.....
Old May 13, 2019 | 04:46 PM
Marcho Polo's Avatar
Marcho Polo
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
did you program for one remote and then when starting the car, it's pre-sets for the other? I don't know if the car keeps different pre-sets for each driver....
Old May 13, 2019 | 07:56 PM
JRGARDEN's Avatar
JRGARDEN
I dont think the radio does that. But if it did why would all my preset stations show up on the dash and nav until I start it, seeing as I unlockec the car with only the one remote.
Old May 13, 2019 | 10:42 PM
Marcho Polo
Former Moderator
Good point. Set them up while the car is running? See if they stay then?
Old May 14, 2019 | 08:20 AM
JRGARDEN's Avatar
JRGARDEN
Thats not a bad idea......stay tuned....
Old May 14, 2019 | 08:54 AM
JRGARDEN's Avatar
JRGARDEN
Finally got thru to someone at the dealership....sounds like a simple re program issue......
Old May 16, 2019 | 07:32 PM
c54u's Avatar
c54u
My favorite buttons on my steering wheel on my 2017 base Stingray do not work until about 1 minute after the car has been running. The electronics take some time to boot up completely. If you have tried waiting for a minute to see if it works or not, then a trip to the dealer may be in order if it does not work.
Old May 16, 2019 | 08:56 PM
JRGARDEN's Avatar
JRGARDEN
I drove for a bit, over several minutes and still did not work. Trip to the dealer
To XM favorite buttons
