Z51 Clutch / Slave Replacement
Old May 20, 2019 | 11:11 AM
ehillard0's Avatar
ehillard0
Default Z51 Clutch / Slave Replacement
Looks like I need to replace the slave cylinder in my 2014 Z51. Anyone have any experience with this, or a general guide beside the service manual? Any help would be appreciated, thanks!
Old May 20, 2019 | 11:15 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
It is a monster undertaking. Lots of parts need to get out of the way before you get at the slave. I'd follow the Helms to get it done if I were doing it.
Elmer
Old May 20, 2019 | 11:29 AM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
If you're not extremely familiar with the car and the work involved, it's not something I would recommend trying to do in the garage for the first time. If you're very mechanically inclined, have a lift and a free weekend, go for it, but be prepared for more than you'd expect if you haven't seen one apart yet.
Old May 20, 2019 | 11:31 AM
RapidC84B's Avatar
RapidC84B
I've done a C5 2X on jackstands... but the C7 has tons of coolers and lines and an e-Diff etc. Would probably fork over the $$$ to a dealer whose done the work before.
What's the car doing? Has the slave blown out completely?
Old May 20, 2019 | 11:44 AM
eboggs_jkvl
Moderator emeritus
In his other thread, he mentioned that the pedal is on the floor.
Elmer
Old May 20, 2019 | 11:59 AM
LuisZ51's Avatar
LuisZ51
It really sucks that this happened but honestly, I would pay the dealer and have everything under warranty. Like others have already stated, it is a ridiculously involved job!
Old May 20, 2019 | 12:01 PM
ehillard0's Avatar
ehillard0
I replaced the clutch and rebuilt the torque tube on my C5 in a weekend, so I'm somewhat mechanically inclined. The Z51 has me worried with all the coolers and ESD. Sounds like I need to just pay to have it done. Thanks for your help.
Old May 20, 2019 | 12:06 PM
ehillard0's Avatar
ehillard0
Clutch master cylinder was empty, adding fluid, and then pumping the clutch pedal just leaks fluid between the bell housing and torque tube. I don't know what else it could really be?
Old May 20, 2019 | 12:40 PM
badhabit_wb's Avatar
badhabit_wb
Mine was leaking from the bleeder because it was not threaded in correctly when new. I managed to chase the threads with a tap and put a Katech remote bleeder in and it solved my problem. It probably won't solve yours but I'd put one on if I replaced it for sure.
Old May 20, 2019 | 12:43 PM
ehillard0's Avatar
ehillard0
Completely agree on the remote bleeder. Did you have to lower the drive line at all to replace the bleeder?
Old May 20, 2019 | 12:47 PM
RapidC84B's Avatar
RapidC84B
Yep... that would be 99% a bad slave.
How in the world did you get a chase up in there to chase it?
Old May 20, 2019 | 12:57 PM
badhabit_wb
I was very motivated! I knew if I couldn't do it I'd have to drop the driveline or I would never have tried it. I was also very lucky that it worked.
To Z51 Clutch / Slave Replacement
