Z06 vacuum fitting part # help?
Old May 25, 2019 | 04:20 PM
Keihin39's Avatar
Keihin39
Default Z06 vacuum fitting part # help?
Hello I need a quick disconnect vacuum fitting it for a 2017 Z06 it is the big fitting right behind the top of the throttle body it has a plastic line that goes down and around the drivers side valve cover to the rear of the motor I no the will not sell just the fitting but if anyone can point me to the part # that would be great I tryed to look it up but can not find it anywhere please if anyone can help me thanks
ray
Old May 25, 2019 | 05:45 PM
laserdude2215's Avatar
laserdude2215
Does your keyboard have one of these "."?
Old May 25, 2019 | 06:00 PM
laserdude2215
Old May 25, 2019 | 06:07 PM
laserdude2215
ACDelco 178-0926 GM Original Equipment Power Brake Booster Vacuum Pipe Assembly
Would you like me to order it for you too?
Old May 25, 2019 | 06:13 PM
Keihin39's Avatar
Keihin39
Hello thank you for your help. I found one on amazon ,thanks again
To Z06 vacuum fitting part # help?
