Headers vs Downpipe pre-76 exhaust smell
Old Jun 8, 2019 | 10:10 AM
RobsCountach`'s Avatar
RobsCountach`
Default Headers vs Downpipe pre-76 exhaust smell
So... Considering just the Cat-less downpipe since not looking to tune due to extended GM Warranty. I've read folks state they didn't want that non-Cat stink; but there's 2 cats (stock) in the mid-pipe, so ?
Besides, headers remove the main, upstream cats anyway.
Is there a difference ?
Old Jun 8, 2019 | 11:11 AM
Kracka's Avatar
Kracka
I went with the high-flow cat AFE downpipes along with a catless Borla X-pipe and have no smell nor a CEL. Great setup, especially paired with my ported/coated exhaust manifolds!
Old Jun 9, 2019 | 09:35 AM
Dcasole's Avatar
Dcasole
Don't remove the cats , you might regret it . I would go the route Kracka went with the AFE high flow cats and the catless x pipe
As far as headers , you have the option for cats and they are located in the mid pipe , yes you can remove the cats but ....
I can't speak for the folks that say they can't smell the car without cats ..... but I can speak for my self . Sitting at a light with the windows open and the wind blowing the wrong way .....or that first start in the morning in the garage ...is terrible
Dave
Old Jun 9, 2019 | 09:59 AM
RobsCountach`
Interesting, it seems the main cats (upper) do more then the mid-pipes. I've always thought the opposite. I still don't understand why its different then headers; they do the same, remove the upper cats ?
Old Jun 9, 2019 | 10:09 AM
Dcasole's Avatar
Dcasole
No they don't do the same ... because headers move the "main cats" down stream into the mid pipe . The density of material in the main cats is much more than the secondary "PUP" cats
The oem pup cats only exist to help with COLD start emissions when the main cats are not hot enough to handle it all . That is the reason why the main cats are located as close to the exhaust ports as possible so they heat up fast
When you go with headers and high flow cats you still will get some smell because the cats are farther downstream and take longer to heat up but once hot ... you won't smell anything . Every time I started my C6 in the garage my wife would comment on how bad it smelled .... I am about to do the same with my C7 ... cant wait to hear her complaints again
Dave
Old Jun 9, 2019 | 10:17 AM
RobsCountach`
Dave
I appreciate the input. Yeah, I did know about the PUP cats job; however, I'm still confused at why there is a difference between headers and the downpipe; Unless, of course, aftermarket mid-pipe cats are more filtering then the stock ? Both 'move' the main cats downstream, or do they ?
Old Jun 9, 2019 | 10:20 AM
Kracka's Avatar
Kracka
Check out my review thread here: https://www.corvetteforum.com/forums...cat-pipes.html
Keeps the cats right where they should be for emissions, warranty, and stock tune reasons.
Old Jun 9, 2019 | 10:38 AM
Dcasole's Avatar
Dcasole
No they do not move the cat , the cat is in the same spot and is also a hi flow cat that is way less restrictive ...because the cat is in the same spot and heats up in relatively the same time frame as stock there is no tune necessary to tune out the 2nd set of O2 sensors that monitor CAT efficiency.
The best if both worlds , a hi flow cat , no smell , and no need to tune ....
But if I am going thru all this work to install these down pipes and we can argue the validity about if they void warranty , for a mininual power gain .... .....then I am going all the way and installing headers and a tune to get the full power gain ...just my two cents
Dave
Old Jun 9, 2019 | 02:14 PM
Z06_Ruff's Avatar
Z06_Ruff
St. Jude Donor '19
I went with Kooks headers/mid-pipe with high flow main and rear cat delete and stock axle back for now. Cold start in the garage can get pretty strong but other than that the smell is minimum at least from my experience.
Old Jun 9, 2019 | 02:41 PM
lakemg's Avatar
lakemg
Same here except I went with the Kooks green cats. No tune, no CEL, and the exhaust odor can be described as your experience. No desire to go catless for me...
Old Jun 9, 2019 | 02:49 PM
Z06_Ruff's Avatar
Z06_Ruff
St. Jude Donor '19
Yes, I meant to say Kooks green cats and I also had no desire to go catless. To each their own.
Old Jun 9, 2019 | 02:54 PM
Kracka's Avatar
Kracka
I went for a nice drive today to get some good logs for my tuner and can confirm no strange smells, nothing stronger than stock odor, with these AFE high-flow cat pipes. Garage cold start, cold idle, driving windows up and down, gas station, then hot idle in the garage.
Old Jun 9, 2019 | 02:56 PM
lakemg's Avatar
lakemg
Did the AFE high-flow cat pipes make the car louder? Are you still running the stock midpipe?
Old Jun 9, 2019 | 03:10 PM
Kracka's Avatar
Kracka
I have a Borla catless X-pipe.
Yes to slightly louder. It's the most obvious at a cold start or heavy acceleration. Minimal change during regular driving or cruising down the highway in Tour. V4 Eco mode sounds about the same too which is nice because I use it a lot on roadtrips.
Old Jun 9, 2019 | 03:25 PM
RobsCountach`
Ugh. I'm not explaining myself well. So Sorry.
I realize they don't 'move' the cat; it was a reference to your post, assuming a virtual move of the main cat downstream ? When you install headrers you ARE running Cat delete, same as the cat-less downpipe. Both options discard the main cats; There's only the mid-pipe cats that remain.
You can not run headers and say you've got all your cats; you don't as you've deleted the 2 main (uppers).
I'm curious why headers don't smell, that retain the mid-pipe cat and the cat-less downpipe may smell, that also reatains the mid-pipe cat.
Both systems are the same; headers and downpipe have NO main cats; they both just have the mid-pipe cats.
Old Jun 9, 2019 | 03:31 PM
lakemg's Avatar
lakemg
The cats that are/can be purchased with header systems are replacements for the main cats and would be considered the main cats. Yes, they are pushed a little further back from the location of where the factory main cats would be, but they are still considered the main cats. It's the smaller downstream (pup) cats that go away with the catless mid-pipe that come with most of the header kits.
Old Jun 9, 2019 | 03:35 PM
RobsCountach`
So what I am failing to understand is that the hi-flow mid-pipe cats are 'beefier' then the stock versions; taking the place of the uppers. In a sense.
To Headers vs Downpipe pre-76 exhaust smell
Old Jun 9, 2019 | 03:45 PM
lakemg's Avatar
lakemg
Correct...don't get too hung up on the fact that they are sometimes called mid-pipe cats. They are typically located in the connection pipe between the headers and the mid-pipe and are not physically part of the actual mid-pipe (at least that's how Kooks system is configured). Their capacity and performance outperform the stock main cats.
More info here: https://performancebusinessmedia.com...ic-converters/
Old Jun 9, 2019 | 03:53 PM
RobsCountach`
Got it...
Thanks all for the answers
Old Jun 9, 2019 | 04:04 PM
lakemg's Avatar
lakemg
Got it...
You betcha...
