Battery change procedures
Old Jun 23, 2019 | 08:20 PM
Prodago's Avatar
Prodago
Default Battery change procedures
is there any certain procedures that I need to follow when changing car battery?
Old Jun 23, 2019 | 08:51 PM
iclick's Avatar
iclick
I haven't done the job yet but have kept the attached PDF for when I do.
File Type: pdf
Old Jun 23, 2019 | 09:03 PM
Prodago's Avatar
Prodago
thanks iclick,
I was thinking about the electronics and if I needed to "shutdown" whatever. but it seems like it is a common battery change.
thanksfor your reply
Old Jun 27, 2019 | 09:04 AM
johnny3's Avatar
johnny3
I jumper a little 9v battery to the cables before
I loosen & remove the cables so nothing is lost.
Old Jun 27, 2019 | 09:10 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
You will lose nothing when you remove and replace the car battery. The only "recovery" that must be done is to re-index the windows. All of your settings, choices, selections, radio stations, NAV favorites are retained.
Elmer
To Battery change procedures
