Stock exhaust question
Old Jul 18, 2019 | 11:14 AM
TURBINE736's Avatar
TURBINE736
Default Stock exhaust question
I’m possibly looking at buying a stock NPP axle back exhaust from a GS to put on my non NPP base model and wanted to know if it should bolt right up or if their not the same size and bend. My car is a 16 and the GS appears to be an 18 if that matters. Thanks for the help
Old Jul 18, 2019 | 11:15 AM
subieworx's Avatar
subieworx
It will bolt up, but you won't be able to use the valves.
Old Jul 18, 2019 | 11:41 AM
RonC7's Avatar
RonC7
The NPP valves will stay open (loud mode). You would need to apply 12 vdc through a switch to be able to open / close from inside the car.
Ron
Old Jul 18, 2019 | 02:12 PM
TURBINE736's Avatar
TURBINE736
Thanks for the info. Would the Z06 axle back also fit on a base model?
Old Jul 18, 2019 | 06:55 PM
Sellout's Avatar
Sellout
The NPP exhausts are all the same, whether its a base car, grand sport, or Z06. The differences are with the AFM valves. Whether they're present (auto) or not (manual)
Old Jul 20, 2019 | 04:19 PM
Bill Dearborn's Avatar
Bill Dearborn
The Z06 axle back won't have the AFM valves required for the LT1 cars. Those are located in the axle back not in the X pipe.
Bill
Old Jul 21, 2019 | 11:23 AM
Sellout's Avatar
Sellout
Bill
I see. Do the Z06 autos never go into V4 mode outside of Eco mode?
To Stock exhaust question
