Caliper comparison info?
Long story short is I no longer have a Corvette, now currently an 03 Mach 1, and I've been racking my brain trying to piece together a viable 4 piston/14" brake kit for it. For simplicity sake, that basis needs to be a GT500 355mm rotor which fits the factory hub nicely. I thought I had it nailed using 370Z caliper which has very similar specs to the GT500 brembo, but the spindle ear sticks out so far on 96-04 mustangs compared to any other car it's a nightmare to work around. So, it's been discovered the factory 330mm rotor is a 95% direct fit to ATS/Camaro/C7 caliper. From the research I've done it seem the Z51 front caliper is identical in all specs, only the mounting ears for the caliper are roughly 1" taller to accommodate the larger rotor and the pads have what seem to be noise dampeners. Is there any other aspect that is confirmed to be different or does anybody have side by sides? Thanks in advance everyone.
I ran the 370Z / G37 Sport Akebono calipers on my older 350Z (with an adapter) and can tell you the C7's calipers are much better. The Nissan units use a super small cotter pin to hold the main sliding pins in place. Finding that tiny hole in the darkness of the wheel well caused me hours of frustration over the years
Where as the C7's pins just tap in and stay put using built-in split ring style washer agreement... OMG so much easier when doing pad swaps.
