ZO6 brake rotor replacement
Aug 18, 2019 | 12:43 PM
Currently own and track a 2017 ZO6 and need to replace the brake rotors.
Looking for recommendations and part numbers if possible. Thanks
Aug 19, 2019 | 07:33 AM
Are you looking to replace with OEM rotors? Front/Rear? Iron/CCB?
For CCB at least, as I've just replaced my front on m 2017:
Front: 20981825
Rear 20981826
Aug 19, 2019 | 07:39 AM
Quote:
Originally Posted by
ScottKolek
Front: 20981825
Rear 20981826
Replace front & rear rotors (iron) and looking for recommendations for either OEM or aftermarket.
Aug 19, 2019 | 02:50 PM
I track my GS, which has the same rotors as the Z06. The OEM front lasted 7 track days, since then I switched to Girodisk. I have 7 track days on the Girodisk, and I don't know how many more days I can get out of them. I am still on the rear OEM after 14 track days. Based on my research on the forum, Girodisk was the best available option for C7. They more expensive than the OEM, but the OEM is not durable for track use. I use Carbotech XP12.
Aug 19, 2019 | 03:33 PM
Thanks for the response GoatHead.
Aug 19, 2019 | 05:47 PM
I recommend the DBA replacement rings. Much better than OEM and much cheaper than Girodisk.
Aug 19, 2019 | 06:02 PM
I’ll take a look at them, thanks PeteC7👍
Aug 21, 2019 | 09:43 AM
For clarification, do the DBA bolt to the stock hat? Are you reusing the hardware?
Aug 21, 2019 | 09:53 AM
Ordered DBA rotors from Ken @ KNS Brakes, great guy with great service.
Yes, will be using stock hats but new hardware also supplied by KNS Brakes.
