Thanks man. Any idea what the difference between the two fan model numbers is? It refers to "With 70mm fan", but no further info. If there is a slimmer version of the fan I'd rather that one as I'm already running a much thicker aftermarket rad.
No, it says with DeWitts 70mm radiator. So if you don't have that, use the other one
Old thread bur hoping this will help someone. 2014 Z51, with Dewitts 70mm radiator and 19.5" fan, Intake duct for Procharger D1X will NOT fit. Looks too close to fan blades to trim the center rib like in the stock fan.
