Low battery
Old Sep 5, 2019 | 11:01 AM
Fun2Day's Avatar
Fun2Day
Default Low battery
After replacing my old battery on my 2015 corvette with a OEM Battery, I get low battery indicator each starting of the car. How can I reset this?
Old Sep 5, 2019 | 11:21 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
It is still mad at something. I'd revisit the battery and make SURE all the connections are aligned as they were when they came from the factory AND I'd then confirm that all connections are good and snug. There is a small single wire that has been known to come off it's spot and that could cause issues too.
Elmer
Old Sep 5, 2019 | 11:25 AM
robert miller's Avatar
robert miller
Default ttt
Elmer
I agree plus those nuts really need to be tq down really good that is what happen to me on my batt chg out on my 2014..
Old Sep 5, 2019 | 06:23 PM
Avanti's Avatar
Avanti
The cable connections must also be clean... on the inside. Many disregard this and can have trouble even though all looks fine. And, it is not impossible to get a bad new battery. I've done so several times over many decades. Hence, before doing anything else, check the battery voltage at the battery. Good luck!
Old Sep 8, 2019 | 08:50 PM
madrob2020's Avatar
madrob2020
I apologize if this is TOTALLY wrong. But, does the DIC indicate start battery low or FOB (RKE) battery low? Sometimes the car warns of low FOB battery. Never hurts to consider everything is why I posted.
Old Sep 9, 2019 | 08:26 AM
eboggs_jkvl
Moderator emeritus
Us old cars (2014) owners don't have those new fangled messages. I do believe you're correct and the DIC will grump when it senses a low FOB battery too.
Elmer
Old Sep 8, 2020 | 10:29 AM
jaybar's Avatar
jaybar
I replaced my battery '17GS with and an AGM battery. It showed 12.6 volts new. I drove about 30 miles came home and checked the voltage at the front fuse box with a voltmeter and got 12.6. I wanted to make sure there was no short in the system so I check the voltage for a few days without starting the car. after 4 days it shows 12.4 v.
So what should a good charged battery read?
I ask because I got a txt from the car telling my battery was low?
Old Sep 8, 2020 | 01:20 PM
Elk's Avatar
Elk
A resting voltage of 12.4V is roughly 75% charged. This is on the low side.
Old Sep 9, 2020 | 12:40 PM
jaybar's Avatar
jaybar
Good information!!
So I put my trickle charger on via the rear power take-off. After 24 hours I am up to 13.5 volts. What would be the max it "should" be?
Old Sep 9, 2020 | 12:59 PM
jaybar's Avatar
jaybar
Originally Posted by jaybar
Good information!!
Well it pays to double check. I disconnected the charger waited a minute, checked the voltage (at the front fuse box) and got 12.5 volts. So the trickle charger brought it up .1 (1/10) of a volt. Seems more like what a trickle charger should do. Is that logical?
Old Sep 12, 2020 | 03:24 PM
Wesley Swayze's Avatar
Wesley Swayze
this was my issue... and how i fixed it. (not my video)
Old Aug 21, 2023 | 04:28 PM
themario's Avatar
themario
Default wire
https://youtu.be/LMi_q7Du9XY
Do you know the gauge of the wire?
To Low battery
