Battery install question stealership
Old Sep 9, 2019 | 12:47 PM
Corvette-Dan's Avatar
Corvette-Dan
Default Battery install question stealership
Do I need to reprogram my car after installing a battery? That is what the stealership said, at a cost of 110 dollars. I have already disconencted it and hooked it back up looking for a date code and no issues outside of indexing windows and top. Are they trying to rip me off? I am going to change it myself anyway and do not want to miss anything. 2014 Z51 3LT auto convertible.
Thoughts?
Old Sep 9, 2019 | 01:06 PM
juanvaldez's Avatar
juanvaldez
Yes.
Old Sep 9, 2019 | 01:09 PM
Corvette-Dan
Originally Posted by juanvaldez
Yes.
I am going with your yes answer as a response to the rip me off question....
Old Sep 9, 2019 | 01:34 PM
laserdude2215's Avatar
laserdude2215
Unbelievable! There are some vehicles (starts with a B ends with a W) that change charge profile over the life of the battery. Not GM!
Old Sep 9, 2019 | 02:16 PM
us3rname's Avatar
us3rname
lol hell no, replace that thing yourself.
Old Sep 9, 2019 | 02:49 PM
BELVIN20's Avatar
BELVIN20
Just re index the windows, & you are ready to go, in some cases when you first start the car, the exterior temp sensor may not read, a short drive & restart my be necessary to bring temp back on screen.
Old Sep 9, 2019 | 04:51 PM
Corvette-Dan
This is what I thought. Thanks to all. I just bought this car June 29 and still learning the newer cars. Rather be safe and somebody call me a dufus than do something harmful.
Old Sep 9, 2019 | 06:00 PM
Maxpowers's Avatar
Maxpowers
Dyver. There are some great writeups in the forum for DYI. JerryU did one. The two most common mistakes are ripping the trunk carpet and not firmly making all the connections. You'll see what I mean when you look at all the bits connected to the battery.
Old Sep 9, 2019 | 09:10 PM
Corvette-Dan
Can I use a 48a? The car has 48ps now.
Old Sep 10, 2019 | 01:03 PM
Avanti's Avatar
Avanti
"Are they trying to rip me off?" Now, just WHY do you think they are called "stealerships" in Forum vernacular?
As I recall, the Owner's Manual gives adequate instructions.
Old Sep 10, 2019 | 01:34 PM
Corvette-Dan
That is assuming that I have one....
Old Sep 10, 2019 | 02:34 PM
Elk's Avatar
Elk
If you do not have an Owner's Manual they are readily available for download.
Old Sep 10, 2019 | 09:36 PM
Corvette-Dan
48a works fine.
Old Sep 10, 2019 | 09:47 PM
No need to have the dealer reprogram anything at a cost of $110.
Old Sep 10, 2019 | 10:25 PM
geraldschumann's Avatar
geraldschumann
The gold Duralast battery H6-DLG from Autozone is an EXACT match and fit. Its the same case as the original Delco and it has an additional 110 CCA.
I have a 2016 Stingray coupe A8, base 1LT.
Old Sep 11, 2019 | 07:19 AM
7LitreC5's Avatar
7LitreC5
No. I never had to reprogram or re-index anything when I replaced the battery in my 15.
Old Sep 21, 2019 | 10:53 PM
Corvette-Dan
This is good to know. How much was it?
To Battery install question stealership
Old Sep 22, 2019 | 01:35 PM
96GS#007's Avatar
96GS#007
BMW has required this for years as part of their Intelligent Battery System. Based on age if the battery, the PCM adjusts the level of charge provided. Less charge equals less drag from the alternator equals better fuel economy.
The downside of not programming is shorter battery life from over-charging a new battery. How much has been the subject of much debate.
Is it needed on a Vette? Doesn’t hurt, the dealer is just reading the book, not necessarily trying to rip you off. Having said that, I’ve never done it with my BMWs and still got 5+ years on the couple I did it with.
Edit: So I glanced at my 2019 Owner's Manual and other than the usual "take it to a dealer so they can diagnose it" language, there's no mention of the need for re-programming. As such....the dealer is trying to lighten your wallet for no reason. As them to show you the requirement.
As an aside, all the Owner's Manuals are available online from Chevy for free download.
Old Sep 27, 2019 | 11:24 PM
KGrant's Avatar
KGrant
I just replaced my 2014 battery myself and did nothing else and everything works just fine like it did before I replaced the battery.
Old Sep 29, 2019 | 02:40 PM
bdutchik's Avatar
bdutchik
Replaced mine, needed 3 hands but for only $118 from Costco, was worth the 25 minutes to change it out.
