C7 battery
Old Sep 9, 2019 | 09:12 PM
Corvette-Dan's Avatar
Corvette-Dan
Default C7 battery
Can I use a 48a? The car has 48ps now. They look the same but the 48a has a higher rating per what the tops say. Thoughts?
Old Sep 9, 2019 | 11:54 PM
RonC7's Avatar
RonC7
Any group 48 should fit. Choose one with at least as many CCA as the original. More is better.
Ron
Old Sep 10, 2019 | 02:53 PM
Antigravity's Avatar
0Antigravity
Former Vendor
Antigravity Batteries has a drop in fit Lithium-Ion Battery for the C7 Corvettes... Weighs only 14 lbs, and save 30lbs off the stock battery ... But the amazing thing is the battery has BUILT-IN WIRELESS Jump Starting. So you will never be stranded by a dead battery again. It also has a lifespan of 8-10 years.
https://antigravitybatteries.com/pro...tive/ag-h6-rs/
Old Sep 10, 2019 | 09:30 PM
Corvette-Dan
Next time. Used A.C. Delco 48A. Fits just like the original and has more power as well. Bought at Menards for 118 dollars. Stealership wanted 190.
Old Jul 4, 2020 | 06:42 PM
c6miller's Avatar
c6miller
I replaced mine with an Interstate Battery MTP-24 two years ago. with 750 CCA. Been very good so far. Well worth the cost.
Old Jul 5, 2020 | 02:47 PM
MMD's Avatar
MMD
Old Jul 5, 2020 | 03:21 PM
MMD's Avatar
MMD
https://www.youtube.com/watch?v=W4zZ0ZAIRkc
$950.00 USD ??? Overpriced. Only a 60 amp-hour battery. You can have that. Optima seems overall to be a better OEM replacement.
File Type: pdf
Old Jul 6, 2020 | 08:20 AM
Doctor Mark's Avatar
Doctor Mark
I would suggest using an AGM battery but do not recommend an Optima. There are many reports of issues with Optima batteries since they moved the manufacture to Mexico.
Old Jul 9, 2020 | 04:40 PM
Chemdawg99's Avatar
Chemdawg99
St. Jude Donor '12 thru '21
Did the same.
Old Jul 9, 2020 | 05:48 PM
Avanti's Avatar
Avanti
Before Optima was bought out I swore buy them, even though back then I had to order them from Summit Racing . However, after getting two faulty ones in short order far more recently I'll not pay their premium price any further. Antigravity might make sense for some racing applications where every pound saved is the primary concern. On the street the price is silly, apart from bench-racing. All the best.
Old Jul 9, 2020 | 06:14 PM
Roadrogue's Avatar
Roadrogue
It’s silly to spend $60k plus on an impractical car in the first place so it’s silly not to buy the best battery for it. Saving 30 lbs is always good and remote emergency starting and double lifetime are even better. And it cranks like a sob, even in a Pittsburgh winter. Oh, and bending over to install it in the recessed hole in the C7 was a nice break for my old back, unlike heaving out that old load of lead. Fit perfectly, too.
To C7 battery
