I like the way yours mounts lot better than I started doing mine. Is that something you fabricated or was it purchased? If fabricated would you be interested in doing another?
Purchased from Leroy trailer hitches. Only Fab work was to drill two 1" hole in the frame. Very easy with a stepped drill. Otherwise everything is provided.
Also, the harness is not "plug and play" like the box states. I was expecting to unplug the tail lights, plug an extender and be done. You have to figure out which wire is which and splice into them. Not hard once you get past the overwhelming number of wires and just use a voltmeter to check each pin as you turn the lights, signals and brake on.
Guys at Leroy clued me into just going back to the basics. This is just a general GM converter, not specific to the Corvette or Leroy.
I need to revisit my wiring. it wasn't until a few days later after doing the wiring I noticed my passenger side taillight was dim. Do you still have the part number for the wiring harness?
Sorry for the misleading info on the harness. Leroy installed a generic one in my car which needed to tap the harness. I bought a backup that was supposed plug into the stock tailights, at least that's what it said. I never actually opened the box to look at it.
I'll get a picture today once they are mounted. I moved the 1 lone tire closer to the others so I can bind all 4 together or else it would be really top heavy by itself.
Nice and compact. Main reason I didnt to HF trailer is the official speed limit. I know tons of people go beyond that with no issues. Just pack the bearings with higher grade grease.
What wheels? Signature?
So I learned the harbor trailer is very over sprung and I need to tighten up the hitch cause it's noisy. I'll remove one of the 3 leaf springs as others have.
I am running Forgestars.
I'm ordering the CF5s tomorrow.
Yeah that little trailer is rated for 1000lbs I think. The Leroy trailers come with proper springs for lighter loads.
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
That's their smaller trailer. Forgive me, but where does the 4th wheel go?
