ATI 15% lower on road course
Old Sep 19, 2019 | 08:37 AM
SnowZ06's Avatar
SnowZ06
Default ATI 15% lower on road course
I recently installed a ATI 15% lower pulley and got a tuned. My question is a road course on a 2 mile track about two times a year. I only go when it’s cool out. Like 80degrees or less. My question is. Is anyone having the supercharger overheat in these conditions with these mods on that M7 car ?
Or do I need to upgrade the heat exchanger and or an expansion tank? I would rather not but I don’t want to damage the car
Old Sep 19, 2019 | 09:28 AM
KCLARK's Avatar
KCLARK
Are you thinking that's from the pulley, what made you even change the spark plug wiring to MSD if your stock wiring works just fine. Stock wires go fine with the colder NGK plugs (do you have those in)?
I doubt your gaining anything from the MSD wires. That 15% damper you added is causing more spin which essentially converting to more heat throughout than your stock set up was designed for.
Short Answer: When doing any pulley changes, YES get a heat exchanger.
Old Sep 19, 2019 | 09:57 AM
SnowZ06's Avatar
SnowZ06
The shop I had install the pulley and tune it recommended putting those in with new plugs. As soon as I saw what happen I put the stock wires back in and it works just fine. And yes one step colder plugs
Old Sep 20, 2019 | 05:07 PM
Avanti's Avatar
Avanti
So, if I'm reading correctly... the shop that did your work attached and/or ran the plug-wire wrong?
Old Sep 20, 2019 | 05:40 PM
SnowZ06's Avatar
SnowZ06
All is fixed now. I put stock wires back on. The MSD Wires were bent and laying against the exhaust manifolds
Old Sep 20, 2019 | 05:43 PM
SnowZ06's Avatar
SnowZ06
I just ordered a Weapon X expansion tank. I’m going to try this first. In theory it holds A lot more fluid so should take longer to heat up. Should be enough to last me through my sessions. We get a good hour to cool down
To ATI 15% lower on road course
