Questions about Alky kit
It has an Alky system installed also. I've been doing as much research on this whole water/methanol injection stuff since I purchased the car, but I want to be sure to take care of it, and not have something go wrong due to negligence.
Under the hood, on the drivers side, there is a lid with "Alkycontrol" on it, connected to a fat black tube running behind the drivers side fender. I assume that tube is connected to the meth tank? I can see the vacuum hoses? running from that direction which connects to the huge air intake. I have not found the Alky control box with the dial/test button or whatever. I assume it's behind the fender along with the tank? I agree that seems ridiculous. But I think I've looked everywhere that I know of and still cannot seem to find it. *EDIT* -- So it appears that it is using the Windshield Washer Fluid Reservoir. Still don't know how to determine if it's full, or what though.
The only feedback I have found so far is the little LED light that's mounted on the left side of the dash. It's a single light (I've seen pictures of dual lights?), that seems to light up red when I "kick it". I've only had the car a few days now, and haven't had a chance to drive it much, still getting used to it (it's a beast). But I "think" I saw it light up white at one point when I accelerated hard. Obviously I'm focusing on controlling the car and wasn't really paying attention to the light.
So, I'm asking for help with this from you experts. I have quite a few questions at this point.
1. How do I know when I need to "refuel" the meth?
2. Is it ok to drive the car if I run out of meth?
3. What is the little light telling me when it turns red (and perhaps white)?
4. What meth should I purchase? I've read that you want a ratio of half meth and half water, and obviously I should be able to mix it myself if needed.
5. If mixing, do I assume I need to use distilled water?
6. If I purchase it "premixed" is "Boost Juice" from Snow Performance sufficient and ok to use?
7. Dumb question -- I assume I pour the meth mixture into the fill spout named "Alky Control" under the hood? Do I just fill it until I can see it in the hose?
8. Any idea where the control box could be in my car?
9. Anything else you can tell me that would be helpful?
Thanks in advance for any help you can provide. I'm hoping to take it to a tuner shop next week to also ask these questions (as well as ton of others about the other mods), and maybe even dyno the car to see what kind of power it's producing.
I ultimately just want to take care of this badass machine. It is absolutely insane at this point.
2. Usually, but I wouldn't beat on it as they typically only activate when sensing a certain amount of air flow. Might be worth finding out if the tune is meth dependent.
3. When the light is red its not making good pressure. when it turns green it means the pump has good pressure. going from red to green quickly is normal.
4. I run 100% Renegade or VP methanol. Keep in mind 100% meth will shorten the lifespan on the pump so it would be advantageous to have a spare and know where your pump is currently located.
5. It definitely wouldn't hurt anything.
6. you could but it may not be as effective as just running straight methanol.
7. Its a safe bet that's where you put the alky. typically its either the washer tank if not mounted in the trunk.
8. Control box should be installed under the rear cargo floor.
9. I would go to you reputable tuner and let them run it on the dyno and let them educate you on your system and give further recommendations if any.
you can find replacement parts and information here
https://www.alkycontrol.com/
https://www.eastcoastsupercharging.c...%206-15-15.pdf
this should give you a good understanding on the kit installation and how to understand how it works.
I've been able to verify the light does go RED, then immediately GREEN under hard acceleration. I've only seen this once however, due to the fact that any hard acceleration (to even test the LED) puts me into the 3 digit speeds. Car is CRAZY fast. lol
Getting it dyno'd tomorrow morning. But I suspect the alky kit is working as intended. I did order some "Boost Juice" by Snow Performance and filled up the "washer" tank (now Alky tank) with it. But at this rate because it seems to only spray under HARD acceleration, I'll probably never use the 4 gallons I purchased. I'm guessing if I can find the Alky controller module, then I can dial it back to a lower number, thereby allowing it to spray under much less boost. Of course, I'm not sure how that would affect the tune --- if the car was even tuned (yeah I don't even know that). I mean I assume it was, but who knows.
You need to get you a spare pump now are at least close to two year with this one.. This pump will start to loose pressure after about 6 mons old & go down more & more with time... Tell your tuner to have the meth to kick in at around 3 lbs of boost.. That should put your setting on the box at least around 7 r 8.. Robert
Again, great info!
