First time suspension work
Old Oct 11, 2019 | 04:20 PM
Johnp94's Avatar
Johnp94
Default First time suspension work
I trying to remove the ends and they are just spinning. Di i use a small rachet on the bolt ends and use a wrench on the lug nuts. Or is there a special
to attach to the bolt ends
Old Oct 11, 2019 | 04:38 PM
ErnieN85's Avatar
ErnieN85
you need two wrenched preferably box wrenches one to hold the stud and one to turn the nut
Old Oct 11, 2019 | 05:02 PM
Johnp94's Avatar
Johnp94
yes, thank you. I figured it out 8 mm and a 18 mm combo. No how do i remove the knuckle. Looks like up better off remiving the strut to lower the upper control arm. How about the leef spring ? Will this slide off ?
Old Oct 11, 2019 | 05:44 PM
Johnp94's Avatar
Johnp94
If i turn this bolt head will it help me remove the lower control arm from the leef spring ? Right now i dont have a ball joint removal tool.
Old Oct 11, 2019 | 05:53 PM
Johnp94's Avatar
Johnp94
Ha, figured that out. Lower the jack and see lower control arm is not bolted to leaf spring 😊😂
To First time suspension work
