C7 electrical problem
Old Oct 22, 2019 | 12:45 AM
Sport16's Avatar
Sport16
4th Gear
Default C7 electrical problem
2016 Stingray-no systems working and after replacing battery-limited service. Car won't start, no gauges, no horn, nothing. Pushing start button while holding brake down I get 5 beeps. In acc mode, windows work, parking lights, rear lights, and cargo lights come on. What's going on?
Old Oct 22, 2019 | 08:55 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
So, you replaced the battery?
Usual problems are:
Loose cable connection. The connections must be made with the wires in the exact position that they came off. If the cable is cocked, the connection might not be firm and the battery fails to supply power.
Did you get any cable arcing when you removed the battery? If yes, you might have blown the 350A fuse on top of the battery.
Elmer
Old Oct 22, 2019 | 10:49 PM
Sport16's Avatar
Sport16
4th Gear
Thanks, made slight adjustment and all is good.
To C7 electrical problem
